Home > Maintenance & Mods (L405) > Oil cooler and coolant leak...
I've had a search but now more confused than ever (doesn't take much) I have a leak down the back of the engine and bellhousing you can see drips quite high up and this at the bottom...
So I take it this comes from either the oil cooler (replaced 3 years ago) or some "O" rings nearby or from a pipe to the thermostat housing....
So a few questions
Is it worth just changing the lot and if so what parts, "O" rings etc are "the lot"...??
Or should I just take it apart and see what's leaking...??
Any other help or ideas please let me know...
Cheers Thumbs Up Pete
Post #715338 1st Apr 2025 1:37pm
Baltic Blue
I base my decision on how long you intend to keep your car.
Assuming a couple of years minimum, then buy some peace of mind and change anything that looks dodgy. The O rings in the water pipes don’t like being disturbed.
Cheers
Post #715346 1st Apr 2025 2:33pm
fisha
Could be from the front of the V at the thermostat pipes. I did a thread about replacing them. uV dye is your friend here for tracing leaks . A couple of bottles into the expansion tank and trace with a Uv torch at night.
For example:
 V8 or else ...
Post #715369 1st Apr 2025 8:35pm
GraemeS
Australia
I suggest that you remove the donut to have a look for the source(s). If it's just the o-rings at the back then you might continue to replace them. My Viton ones needed to be replaced again at about the same interval. MY21.5 D350 Vogue SE Carpathian Grey
Post #715379 1st Apr 2025 11:12pm
BAZ8046
When I had a coolant leak showing at the back it was from the bottom of the thermostat housing.
I did the front o-rings and top of thermostat housing first but still had a leak.
You do damage the housing getting it out but it looks like the o-ring goes flat and they crack around the bottom fitting.
 2012 TDV8 4.4 Westminster Santorini black
2016 Discovery 4 Landmark
2002 Defender TD5
Post #715382 2nd Apr 2025 8:27am
Mike, Much what I was thinking... Thumbs Up
Fisha, the bright orange coolant seems easy to see at the moment, when I get it all apart is another matter... Thumbs Up
GraemeS Just trying to pre-empt what I might need, can you remember the size of the "O" rings needed...?? Thumbs Up
Baz8046 Handy pictures, Thanks for them and the info... Thumbs Up
Well I've ordered a new oil cooler and filter, and both halves of the thermostat and housing...
Anyone know of anything else to do under there, "O" rings etc and sizes if you have them?
Cheers
Ordered both parts, basically everything inside the two black boxes...!!
 Pete
Post #715387 2nd Apr 2025 10:13am
Strip down of the top of engine stuff is pretty straight forward Pete. It all looks tight but once you have the secondary bulkhead and plenum off then you can see most of it. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #715392 2nd Apr 2025 10:34am
Cheers for that, just trying to make sure I have all the bits so it's not off the road for long... Thumbs Up
I get withdrawal symptoms if I can't drive it.... Rolling Eyes Pete
Post #715402 2nd Apr 2025 10:58am
toby1
This may help: https://www.fullfatrr.com/forum/topic66813...+hose+seal 2012 Vogue TDV8 in Aintree green over sand
Post #715412 2nd Apr 2025 12:33pm
Cheers, I knew I'd seen that somewhere, used search, never found it...... Pete
Post #715417 2nd Apr 2025 1:12pm
GraemeS
Australia
BS611 Viton are good fit o-rings on the turbo oil feed fitting. MY21.5 D350 Vogue SE Carpathian Grey
Post #715424 2nd Apr 2025 1:57pm
Cheers, do you happen to know the size of them...?? Pete
Post #715440 2nd Apr 2025 5:56pm
GraemeS
Australia
BS611 has ID 8.73mm and CS 1.78mm (OD 12.29mm)
The groove in the fitting is 9mm OD and the hole in the oil cooler is 12m ID. MY21.5 D350 Vogue SE Carpathian Grey
Post #715448 2nd Apr 2025 8:54pm
Cheers... Thumbs Up Pete
Post #715452 2nd Apr 2025 11:15pm
