![]() | Home > In Car Electronics (L405) > CarPlay issues after latest SW update |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35604 ![]() ![]() |
my only suggestion is to reboot the whole car by disconnecting the battery foe a while.. ... - .- -.
EV_Simon Member Since: 14 Jan 2025 Location: Norfolk Posts: 14 ![]() ![]() ![]() |
Hi Stan, thanks for the suggestion.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1662 ![]() ![]() ![]() |
Disconnect the battery completely BOTH terminals, and touch the terminals together for 10 seconds, replace the negative first, then the positive.
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 234 ![]() ![]() |
The latest version of the InControl Touch Pro software is 21B. ISTR there were several CarPlay improvements from 19C. I'm not sure if with the OTA updates they need to install in sequence (if they do you have several more updates to go)
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2640 ![]() ![]() |
When connecting a totally-disconnected battery, it's good practice to connect the positive first in case the spanner touches metalwork whereby it cannot short the battery because the negative isn't connected, then connect the negative as the spanner touching metalwork isn't an issue. MY21.5 D350 Vogue SE Carpathian Grey |
