Home > Maintenance & Mods (L405) > Anyone - Cleaning out the drain plugs
Page 3 of 3 <123
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
There’s a sharp bend where the drains change direction to go down the C-pillar - didn’t want to force the drain brush down given how much effort it was taking, so I might blast a bit of compressed air through them in future.
On a 10k mile car with no blockages, the entrance holes of the drains were just starting to rust…
Post #715257 31st Mar 2025 11:36am
caymanblack
If your drain holes are still ok this is a great answer to the problem. I have done mine.
 overfinch modified
Post #715328 1st Apr 2025 10:17am
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Thank you for sharing. I will hopefully get time this weekend to check them.
Then plan the preventative fix.
I was also able to see the clips and placement in the video. So that helps me to be able to remove the trim. SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #715331 1st Apr 2025 10:45am
luxmoggy
I managed to check them tonight. No blocks and no rust. So I will look to order the pipe inserts before anything happens. SDV8 AB MY 2020
Post #715445 2nd Apr 2025 7:55pm
Kot
The 2nd video from the same UTuber as a follow up, is a must watch as well, as it shows the end of the drain pipe that is removable exiting where aux battery is and can be used to also assist clearing blockages etc
 2018 SE SDV8 4.4 Byron Blue
Post #715466 3rd Apr 2025 9:44am
caymanblack
Thanks Kot. Thumbs Up overfinch modified
Post #715503 3rd Apr 2025 8:54pm
Page 3 of 3 <123
