![]() | Home > Maintenance & Mods (L405) > Anyone - Cleaning out the drain plugs |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1163 ![]() ![]() ![]() |
If your drain holes are still ok this is a great answer to the problem. I have done mine.
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 494 ![]() ![]() ![]() |
Thank you for sharing. I will hopefully get time this weekend to check them.
I managed to check them tonight. No blocks and no rust. So I will look to order the pipe inserts before anything happens. SDV8 AB MY 2020
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1313 ![]() ![]() |
The 2nd video from the same UTuber as a follow up, is a must watch as well, as it shows the end of the drain pipe that is removable exiting where aux battery is and can be used to also assist clearing blockages etc
Thanks Kot. |
