![]() | Home > Maintenance & Mods (L405) > Anyone good with the HVAC system operation / values ? |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 303 ![]() ![]() ![]() |
I had very similar on my SDV8 and it was the diverter valve on the FBH, check the temp of the 2 water hoses going upto the EGR from the FBH, they should both be the same temp, I had one hot and the other cold and it caused differing temps on either side of the cabin. New diverter valve and normality resumed. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 151 ![]() ![]() ![]() |
You might be missing some teeth on the blend door actuator. They are plastic tooth and drive so do commonly wear out.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1473 ![]() ![]() |
I glanced at the pressure values last night and they seemed ok, plus the cold air is getting fully cold evenly so I’m less inclined to think this is the issue at this time, but I’ll dig out the charts and compared just in case.
I had just the same, hot both sides initially and then heat dropping, more on passenger side but drivers side still wasn't hot even on high setting. It also affected the rear climate, which kind of makes sense because the valve is isolating the interior from the coolant loop to aid cold starting.
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 118 ![]() ![]() ![]() |
I think in my mind it could be either the diverter valve, or the heater matrix, or possibly both.
All valid points and similar to my thoughts, but the more I think about it, the valve makes the most sense.
Totally this, plus if the matrix was blocked why would you get even heat initially. I was pleasantly surprised it was such an easy fix, expected to be pulling the dash to change the matrix at one point! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
So drove home from work just there and logged it … pretty conclusive to what we’ve talked about. Monitored vent temps, ambient and evaporator temps as well as whether flame detected on the fbh.
So the left and right side are equal temperatures while the FBH runs, so to me that says that the heater matrix is fine, and the diverter valve is the most likely culprit.
dupe post. V8 or else ... |
So to close out.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1317 ![]() ![]() |
Put it in Auto and set to required temperature --- simples |
The point here is that it can't maintain the required temperatures. |
I do that.
