Home > Technical (L405) > L405 Grinding/Rumbling Noise at Rear When Pulling Away
Stuart-
[quote="D3Jon"]
Stuart- wrote:
I'd listen to your Indy if they recommend leaving alone.
This is where I am stuck between a rock and a hard place now. Since they changed the transfer box oil, it's got worse if anything. So I have since asked them to do this reset, and they said they'd rather not, they'd prefer to change the oil in it again and put some "anti judder" in.
I don't know why they seem reluctant to do the reset, though. I can't get any sense out of them on that.
I did find on an older topic here:
pld118 wrote:
The symptoms can occur before or after a transfer box oil change.
The LTB is:
" LTB00906v6 - Twin Speed Transfer Case Judder "
" A customer may express a concern that a judder is felt from underneath the vehicle when using steering input at low speeds, for example turning left or right at a junction. This technical bulletin has been updated due to a change to the warranty section, parts section, condition summary and service instruction. "
If you present your car to a LR Main Dealer with judder symptoms, they might suggest a transfer box double flush, road test and software update. Our car displayed these symptoms (3.0 TDv6). The procedure was recommended and resolved the issue. The LR Main Dealer applied no charge for the procedure.
The symptoms can be the subject of an LR warranty claim.
I'm minded to bung it in the main dealer if this comes under warranty. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #714751 24th Mar 2025 2:01pm
D3Jon
Maybe let your Indy do the double flush? That's go to be the cheapest and possibly the quickest step. It might well solve the issue, it's certainly in line with the TSB your quote referenced.
Not sure why they'd be reluctant to do the TC clutch calibration, though? They must have their reasons, perhaps press them a bit more on their reasoning? I wonder if they've had issues in the past or lunched a customers TC? I'm sure they're diag kit will do it - I assume they are a LR Indy and not just a generic garage?
I've never personally done a TC clutch calibration, as usually a fluid change takes that judder / graunch you get when setting off from a junction with a fair amount of steering lock on (my old L322 TDV8 used to do it when pulling out of right hand junctions).
Let us all know how you get on! Thumbs Up
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #714782 24th Mar 2025 5:29pm
D3Jon
Just to add, these Transfer Cases are very fussy about which oil is in them. It's a specific weight of oil with special friction modifiers.
Just a thought? If you're 'Indy' isn't an LR specific Indy and is throwing 80/90 gear oil in there!
But if they are an LR Indy, I wouldn't even question them (they may take offence), they'll know what to put in!
2014 Disco 4 HSE
Post #714784 24th Mar 2025 5:34pm
Stuart-
Yes, they are a LR indy specialist.
I emailed the local main stealer yesterday with the bulletin number, It's booked in, in four weeks for them to look at and calibrate the steps that the indy couldn't do either.
The fact they couldn't calibrate the steps either, tells me its more about the kit they have that might not be up to L405s generally. I'm not keen on having tins of Dr Tranny or some anti-judder stuff added in there if its not necessary and a calibration is all that is needed.
They're usually OK. I've used them for years. But I have had less success with stuff generally with them since going into an L405.
I'll update when Sytner has had a look. 2017 4.4 SDV8 Autobiography in black
Post #714860 25th Mar 2025 1:02pm
GraemeS
Australia
Is your vehicle MY18 built in 2017? MY21.5 D350 Vogue SE Carpathian Grey
Post #714885 25th Mar 2025 8:43pm
Stuart-
I'm not sure. How to know? It's the cross-over spec in terms of the central screens. IIRC, 2017 models have screens that are not quite pre-2018 and not quite post-2018. 2017 4.4 SDV8 Autobiography in black
Post #714923 26th Mar 2025 12:28pm
GraemeS
Australia
The VIN will indicate the MY.
I ask because somewhere, possibly starting with MY18 although I've seen reference to MY20, the OBD protocol changed for some ecus causing older diagnostic tools to no longer work on all modules. My MY21.5 requires the G4 Gap diagnostic tool to access some ecus but an old G2 will still access other ecus. MY21.5 D350 Vogue SE Carpathian Grey
Post #714928 26th Mar 2025 12:57pm
Stuart-
I just put my chassis number in GPT and it told me its a MY 2017.
On tools, it also said this: Starting from Model Year (MY) 2017, Land Rover transitioned to a new electronic architecture, which introduced different communication protocols for certain Electronic Control Units (ECUs). This change means that some diagnostic tools compatible with earlier models may not fully communicate with all ECUs in MY2017 and later vehicles.
I think my Indy is using an old diagnostic tool/software version. That would explain reluctance to calibrate the clutches and inability to calibrate the deployable steps. 2017 4.4 SDV8 Autobiography in black
Post #714933 26th Mar 2025 2:07pm
GraemeS
Australia
Thanks for confirming the starting MY. MY21.5 D350 Vogue SE Carpathian Grey
Post #714950 26th Mar 2025 9:16pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
i had this transfer issue when i got my l405 but did the double flush and software update and has been working fine since
Post #714971 27th Mar 2025 12:12pm
