![]() | Home > Technical (L405) > L405 Grinding/Rumbling Noise at Rear When Pulling Away |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 373 ![]() ![]() ![]() |
[quote="D3Jon"]
This is where I am stuck between a rock and a hard place now. Since they changed the transfer box oil, it's got worse if anything. So I have since asked them to do this reset, and they said they'd rather not, they'd prefer to change the oil in it again and put some "anti judder" in. I don't know why they seem reluctant to do the reset, though. I can't get any sense out of them on that. I did find on an older topic here:
I'm minded to bung it in the main dealer if this comes under warranty. 2017 4.4 SDV8 Autobiography in black 2018 D300 SE Velar in champagne 1982 Rolls Royce Silver Spirit in green Spiffing wheel centre caps, L322 sill repair panels, etc |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 519 ![]() ![]() |
Just to add, these Transfer Cases are very fussy about which oil is in them. It's a specific weight of oil with special friction modifiers.
Yes, they are a LR indy specialist.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2655 ![]() ![]() |
Is your vehicle MY18 built in 2017? D350 SE Carpathian Grey D5 19" rims |
I'm not sure. How to know? It's the cross-over spec in terms of the central screens. IIRC, 2017 models have screens that are not quite pre-2018 and not quite post-2018. 2017 4.4 SDV8 Autobiography in black
The VIN will indicate the MY.
I just put my chassis number in GPT and it told me its a MY 2017.
Thanks for confirming the starting MY. D350 SE Carpathian Grey D5 19" rims |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 516 ![]() ![]() ![]() |
i had this transfer issue when i got my l405 but did the double flush and software update and has been working fine since |
Update for others: So it's just been in Sytner, they changed the oil in the transfer box again and "updated the module" as they called it, which when pressed seems to be one and the same as resetting it discussed above. And it seems OK now.
resetting is not the same as a software update so maybe confirm what they have done 👍 |
On the invoice, it says they flushed it, changed the oil and did a "module update", which GPT says:
