![]() | Home > Technical (L322) > Low range help |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
When you perform the range change from High to Low, does the low range indicator light on the instrument panel flash while the range change is occurring, and then illuminate constantly? Also, do you get a warning chime sound and ‘LOW RANGE’ displayed in the message centre for a few seconds after the change?
Philcaz Member Since: 18 Apr 2020 Location: London Posts: 20 ![]() ![]() |
Hi mate
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
I dont know if its related, but we had a 4.4V8 L322 petrol (now a 4.2S/C )and ours was jerky going into (mostly) reverse), , not sure if there were any codes but the opinion was a possible crack or leakage in the valve block. |
Thanks mate for your reply we haven’t got a clue at the moment what it could be |
The ‘Noise on actuator signal’ error generally means that the potentiometer in the transfer box shift motor is producing an intermittent signal.
Thanks Phil
