![]() | Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1311 ![]() ![]() |
There are 2 connection profiles Landrover and Rangerover. Use the RangeRover profile and RangeRover 2017-2021 is for facelift SDV8 2018 SE SDV8 4.4 Byron Blue |
Bozman82 Member Since: 17 Mar 2025 Location: Wales Posts: 12 ![]() ![]() |
So I used the setup for the first time yesterday. I had an active and a passive regen on a 15 mile journey. Both were pretty quick. The concerning thing for me is that my average distance between regens is 72.7 miles. Would this be down to a lot of failed regens? My service light was reset by land rover in January and came on again after about 1500 miles. Generally I'm doing short journeys with a 50 mile round trip once a week. The photo shows my stats after my trip |
If your service light came on, you need to immediately change the oil and reset the service counter again. It's easy with a vacuum pump.
Thanks Kot,
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 113 ![]() ![]() ![]() |
If it has only been 1500 miles since the last service, I would be interested to see the data from the Powertrain Control Module for: Distance to next service, Accumulated distance since last oil change, Oil quality dilution factor. (These are available on a 2013 RR, as yours is newer the data points might be different). |
goldeneye32 Member Since: 10 Jan 2024 Location: Hampshire Posts: 66 ![]() ![]() ![]() |
I had an Oil Service (interim) on mine in early December and nearly 5000 miles later it's not yet come up with the 'Service Required' message yet, looking at your MPG it is a bit of a giveaway to your use, I travel 33 miles to work along a dual carriageway and a motorway for 28 miles of that journey, so it gets a decent run, and my mpg is in the early thirtees, and your's is showing early twentees.
Brilliant, thanks Goldeneye.
I wasn't aware of the oil dilution issue until after I'd bought mine either, retrospectively I'd have been better going for the 5.0 V8 petrol, but I already have a 6.0 V12 in the garage! |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1667 ![]() ![]() ![]() |
Just a quick mention, the Smith & Allen Momentum C1 5W30 is only £22.50/5L delivered if you buy the 20L size, and meets ST JLR.03.5005. Not worth paying premium price if you’re changing oil every 2K-3K miles. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
Ooh what have you got?? Aston?? |
Thanks gremlin. Not at at all. So much for the DPFs being better for the environment |
You only need to pay for the yearly/16k service and even then it can be any VAT registered garage but better if the garage can access OSH. That satisfies the requirement for warranty people to have the car serviced as per JLR requirements. All other interim oil changes do it yourself we all do! ![]() But yeh like many should have bought a petrol. ![]() |
You win Cant beat that even with current discount 15% off at OPIE The best I can get, is 10L of Millers Oils Trident Professional C1 5w-30 Fully Synthetic Engine Oil for £50.96 with free delivery JLR spec etc 2018 SE SDV8 4.4 Byron Blue |
