Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol
Page 29 of 30 <123 ... 282930>
Bozman82
luxmoggy wrote:
Mine is a 2020 4.4 SDV8
How are you setup on the car scanner app? I couldn't see an option for the 2016 onwards SDV8
Post #714260 17th Mar 2025 5:58pm
Kot
There are 2 connection profiles Landrover and Rangerover. Use the RangeRover profile and RangeRover 2017-2021 is for facelift SDV8 2018 SE SDV8 4.4 Byron Blue
Post #714288 17th Mar 2025 11:03pm
Bozman82
So I used the setup for the first time yesterday. I had an active and a passive regen on a 15 mile journey. Both were pretty quick. The concerning thing for me is that my average distance between regens is 72.7 miles. Would this be down to a lot of failed regens? My service light was reset by land rover in January and came on again after about 1500 miles. Generally I'm doing short journeys with a 50 mile round trip once a week. The photo shows my stats after my trip
Post #714713 24th Mar 2025 7:06am
Kot
If your service light came on, you need to immediately change the oil and reset the service counter again. It's easy with a vacuum pump.
I have similar low distance between AR as I live semi rural and have a lot of short journeys. You are also doing a lot of short journeys also and have relatively slow speeds under 60mph etc
Your mileage between Active Regens is low because of this. I can be changing oil between 2000/3000 miles, your distance between AR would be lower if you continually do short journeys, and stop the car during a AR.
It will only increase (distance between AR) once you regularly do long journeys (100-200+ miles) at Motorway speeds as this gets the exhaust temps across dpf above 250-300 Celsius when Passive Regeneration occurs (1). In reality you need +70mph Rolling with laughter
Throughout the motorway journey the soot load still increases but at a more gradual rate as PR is trying to burn away generated soot load. The algorithm learns from this and mileage between AR will increase.
The PR (1) you saw, was temporary because your dpf exhaust temperature just got up to the 250-300Celsius range then fell back down again. To ensure you maintain PR it has to be on constantly so your DPF temperatures need to be in that range all the time. Having the (1) for a few seconds wont achieve anything. 2018 SE SDV8 4.4 Byron Blue
Post #714724 24th Mar 2025 9:08am
Bozman82
Thanks Kot,
The problem I have is I still have over 2 years warranty left on the car so I'm going to have to pay for the service. After the warranty is up it's going back to Land Rover for good. Hopefully with the Kot Kit I can reduce my services tho.
Post #714727 24th Mar 2025 9:27am
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
If it has only been 1500 miles since the last service, I would be interested to see the data from the Powertrain Control Module for: Distance to next service, Accumulated distance since last oil change, Oil quality dilution factor. (These are available on a 2013 RR, as yours is newer the data points might be different).
Post #714735 24th Mar 2025 10:25am
goldeneye32
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
I had an Oil Service (interim) on mine in early December and nearly 5000 miles later it's not yet come up with the 'Service Required' message yet, looking at your MPG it is a bit of a giveaway to your use, I travel 33 miles to work along a dual carriageway and a motorway for 28 miles of that journey, so it gets a decent run, and my mpg is in the early thirtees, and your's is showing early twentees.
I buy my own oil from Opie Oils (out of stock at the minute), but my indy does the service for about a ton (Filter and sump plug), and i supply the oil (C1 below)
https://www.opieoils.co.uk/p-218910-petron...tid=354694
May I compliment you on your choice of colour!
Wish I read my posts before uploading, I might get some of the spolling correct!
Post #714750 24th Mar 2025 12:58pm
Bozman82
Brilliant, thanks Goldeneye.
The colour was the reason I bought it. I was happy in my Golf edition 35 but the wife wasn't 🤣
If I had known I would have these issues I wouldn't have bought it. The salesman never said anything when I said I live 5 miles away from work and don't do a great deal of miles.
I've done 5k in it now and this will be it's "3rd" service if you include the reset by LR.
My mpg is quite low as I had a full software update to fix some flickering/off screens a couple of weeks back. Well so I'm telling myself but it was averaging 28 ish
Post #714755 24th Mar 2025 1:13pm
goldeneye32
I wasn't aware of the oil dilution issue until after I'd bought mine either, retrospectively I'd have been better going for the 5.0 V8 petrol, but I already have a 6.0 V12 in the garage!
Post #714756 24th Mar 2025 1:17pm
Gremlin500
Just a quick mention, the Smith & Allen Momentum C1 5W30 is only ÂŁ22.50/5L delivered if you buy the 20L size, and meets ST JLR.03.5005. Not worth paying premium price if you’re changing oil every 2K-3K miles. â€śIf it ain’t broke, don’t fix it” -where’s the fun in that?
Post #714757 24th Mar 2025 1:17pm
Bozman82
Ooh what have you got?? Aston??
Post #714758 24th Mar 2025 1:22pm
Bozman82
Gremlin500 wrote:
Just a quick mention, the Smith & Allen Momentum C1 5W30 is only £22.50/5L delivered if you buy the 20L size, and meets ST JLR.03.5005. Not worth paying premium price if you’re changing oil every 2K-3K miles.
Thanks gremlin. Not at at all. So much for the DPFs being better for the environment
Post #714759 24th Mar 2025 1:25pm
Kot
Bozman82 wrote:
Thanks Kot,
You only need to pay for the yearly/16k service and even then it can be any VAT registered garage but better if the garage can access OSH. That satisfies the requirement for warranty people to have the car serviced as per JLR requirements.
All other interim oil changes do it yourself we all do! Thumbs Up
But yeh like many should have bought a petrol. Whistle 2018 SE SDV8 4.4 Byron Blue
Post #714764 24th Mar 2025 1:44pm
Kot
You win
Cant beat that even with current discount 15% off at OPIE
The best I can get, is 10L of Millers Oils Trident Professional C1 5w-30 Fully Synthetic Engine Oil for ÂŁ50.96 with free delivery JLR spec etc 2018 SE SDV8 4.4 Byron Blue
Post #714765 24th Mar 2025 1:58pm
goldeneye32
Post #714766 24th Mar 2025 2:01pm
