![]() | Home > Technical (L405) > Deployable Tow Bar |
qwerty Member Since: 21 Oct 2015 Location: Bristol Posts: 60 ![]() ![]() |
Yes it is spring loaded to the opertional position, ie down so should drop. It will be seized and with the tow bar deployed you shoud be able to free it with gradual rocking. They seize really easily. |
MwestcrewRR Member Since: 13 Mar 2025 Location: South Warwickshire Posts: 8 ![]() ![]() ![]() |
So does the tow bar normally keep it up in place? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7991 ![]() ![]() ![]() |
Yes - mine normally drops down as the tow ball does & it then gets pushed back up when it's stowed. |
Marmoset Member Since: 14 Feb 2025 Location: Cheshire Posts: 4 ![]() ![]() ![]() |
Had the same with mine that I picked up a few weeks ago. A liberal application of WD40 to the pivot of the socket for a few days freed it up. |
