Home > Range Rover P38 > Bordeaux
Page 8 of 8 <12345678
Huttopia
Last week I finally managed to take the P38 to 4x4 Development where a test for (carbon monoxide?) in the coolant tank confirmed the worst.
The plan is to get the engine out and over to Turners where it will be rebuilt with liners, kent cam and I think a stage 1 ported / gas flowed head. May as well whilst it is out. The slight leak on the torque converter can also be fixed. Dave at 4x4 suggested we replace the rad and a few other bits at the same time, which I guess makes sense other than financially Laughing
I could get an exchange unit from Turners but that would then not be matching numbers, which seems a bit daft. I've no expectation she'll be worth a great deal in X years, but then I guess folk cutting up Suffix As for trialing thought the same.
Post #683508 22nd Jan 2024 10:31am
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
If you get top hat liners fitted, ask Turners to NOT machine off the engine number when they deck the block.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #683569 22nd Jan 2024 7:38pm
Huttopia
Top tip, thank you.
Post #683575 22nd Jan 2024 8:08pm
Huttopia
She’s gone to the menders…finally! A friend of mine has lots of experience with Rover V8s and has done nut and bolt rebuilds on a range of cars from Jensens to Classic RR, E-type and 911, top man. Looking forward to the results
Post #714175 16th Mar 2025 5:33pm
