Home > Maintenance & Mods (L322) > Please help...
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
Please help...
Hi
My 4.4 TDV8 has been showing the red triangle/restricted performance intermittently.
It only happens if I rev to approx 3k and then keep my foot down so as it changes gear I remain above 2.5k. If I rev to 3k which I do most drives to keep the 2nd turbo in use (only rev above 2k once fully warmed up) i do not get the restricted performance.
I noticed some oil gathering around the plastic intake where that strange metal clip is that holds the intake pipe to the throttle body. I have removed, cleaned including the air sensor and replaced adding 2 rubber O rings. It seems to seat nice and tight so all back together now.
Would this have caused the restricted performance as it just have been only a slight leak?
I have checked all 4 hoses to the doughnut/plenum and they are all good.
Update, I can accelerate to 3k revs and gently lift off so when the gear changes the revs are below 2.5k and mostly no light. If I put in sport and rev to 3k the restricted performance happens every time.
No smoke, perfect tickler, no missing or lumpyness. I really want to fix myself and am considering replacing both MAF sensors and the MAP sensor, is this sensible?
Thanks 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #714171 16th Mar 2025 3:57pm
Eastsoutheast
These are the codes I get when my car goes into restricted performance.
It will clear on its own after 10 mins or immediately using OBD scanner.
What next please?
Post #714173 16th Mar 2025 4:55pm
