![]() | Home > Technical (L322) > Possible leak from top of windscreen or sunroof? |
BAZ8046 Member Since: 26 May 2023 Location: Chatham Posts: 35 ![]() ![]() ![]() |
Hi,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8533 ![]() ![]() ![]() |
And FYI that trim you have arrowed will have been damaged when they changed a screen previously, then the fitters glue that trim in so it doesn't fall out...
WheelNut Member Since: 30 Jan 2025 Location: Vancouver, Canada Posts: 18 ![]() ![]() ![]() |
I did a sunroof drain test last week, but I'll do a more intensive one this week. I'll do a leak test on the windshield as well. 2006 Range Rover 4.4L Gas
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
Looks like mine a few months ago…i tracked mine down to the front left sunroof drain being partially blocked.
Update: I did a test with the garden hose and the leak is indeed from the windshield. Photos show where water has dripped from seal onto headliner. You can also see how water dripped down onto the right side of the center console in one photo.
If that doesn't work a new seal is not a lot of money, you then rip the old one out, sort out the leak and replace the seal, or get a windscreen replacement company to do it, they will have done it lots on all different cars... |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Might be worth trying this https://www.ebay.co.uk/itm/167372298823?_s...R4T-gLK0ZQ
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
There should be a continuous bead of sealant all the way round the screen, which is what stops the water. The rubber is just a finisher really.
I called a local glass shop here in Vancouver a week ago and they told me that they could take the windshield out and re-install it, but "...if it breaks when we take it out YOU have to pay for it, and sometimes they break...oh, and those windshields are special order from the UK only, 6 months to get one" This is a pretty typical response from a Canadian tradesman. The translation is, of course, that they don't want to touch this job. I'm pretty used to this- tough to get good help around here, so I do most everything myself. Not sure if my work really qualifies as "good or help", but at least I'm cheap and I know who to blame! Hahaha.
Good suggestion. That would probably work great. I'll bookmark that just in case my fix doesn't work. 2006 Range Rover 4.4L Gas 2006 BMW 330i 6MT 2024 Mazda CX-5 |
This fix seems to be a success. We’ve been getting pummelled with rain for the last few days and the headliner is dry as a bone. My spare tire well had about a centimetre of water in it though, so that’s the next thing to fix. 2006 Range Rover 4.4L Gas
