Home > Technical (L405) > Anyone come up with a solution for the cutout in boot
I'm another with a net - mine came from the L322 but any net will do - loads on eBay.
The retention on the left is easy as the panel removes - a but more fiddly on the right, but there is enough flex to get a nut behind.
I had an AutoGlym Lifeshine bag that fills the gap perfectly.
Post #554031 16th May 2020 6:49am
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
I have the net like Supershuttle’s, fitted over a hatchbag bootliner and secured with small cable ties. No drilling required!
Post #554039 16th May 2020 9:01am
Chalky
As the Hatchbag liner covers the hole, I just put everything behind it, and undo the little velcro tabs to open up the space to get to things kept behind it. Thumbs Up All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #554073 16th May 2020 2:24pm
Vogue
Piccies needed please !!!! I hate drilling holes in cars as I always change my mind and regret it Wink 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #554094 16th May 2020 5:14pm
supershuttle
I just used little black screws, I’ve moved it once - no holes and of course no drilling required Geoff
Post #554097 16th May 2020 5:40pm
Chalky
I know these will come out the wrong way up (still can't get pics to work!! Censored ) but here's the hatchbag liner and then t pulled back to reveal the hole for storage..
Post #554104 16th May 2020 6:19pm
BlackPerth
Australia 2017 Range Rover Vogue SE SDV8 Mariana Black
I put my large 105AH battery for my fridge in this space, with a custom leather cover reusing the vent. All done by Osborn Park Autospark in Perth if any Aussies are interested.
 2017 Range Rover Vogue SE SDV8 (with e-diff)
2012 Range Rover Vogue TDV8 Luxury (SOLD)
2010 Land Rover Discovery 4 3.0 TDV6 HSE Stornoway Grey (SOLD)
2006 Land Rover Discovery 3 SE 2.7TDV6 Black, G4 Challenge Copy (gone)
Post #554126 16th May 2020 9:17pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
adara wrote:
I bought a cheap nice auto bag from Lidl, that fits exactly in that space… It won't move, as the boot floor is raised 4cm on the P400e. I also fitted an elastic band to keep the charging cable bag from occupying too much space. I don’t like the solution JLR found for the cable storage… And I can’t understand why the boot is not recessed on the left side too, there is A LOT of space that isn’t used at all over there… Just remove the left side panel and check for yourself!
can i ask where you got the bag thats in the hole please
thanks
Post #713602 8th Mar 2025 8:10pm
Mine's an Autoglym Lifeshine bag - available on eBay - and fits well
Post #713605 8th Mar 2025 8:42pm
will308f
Thumbs Up thanks
Post #713608 8th Mar 2025 8:54pm
