![]() | Home > Technical (L405) > Anyone come up with a solution for the cutout in boot |
modbarra Member Since: 28 Mar 2009 Location: northampton Posts: 237 ![]() ![]() ![]() |
Not sure how to uplift photo from my gallery........ If you look on my gallery photos (no 11).... i put a net from L322 on there...... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35588 ![]() ![]() |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 ![]() ![]() ![]() |
Well now Stan that's exactly what I'm after. Can I ask if they are just short grub screws or similar holding it? 2016 SDV8 Autobiography
I appreciate the assistance but I'me probably worse than you on the tech side of things and although I've had a look at your profile I can't find any pics. But Thanks 2016 SDV8 Autobiography And several others previously. |
that is the pic that modborra couldnt post mr faulty... ... - .- -.
Good to have someone who knows what he's doing |
Just done it. Absolutely Great. Thank you both so much!! |
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
I fitted the load retention kit and it works a treat! 2010 defender utility
Mariana Black Member Since: 30 Jul 2014 Location: Stockton-on-Tees Posts: 89 ![]() ![]() ![]() |
I had found this but the price is putting me off.....
3.0 Autobiography 14M5 |
karba78 Member Since: 21 Mar 2020 Location: Plaisir Posts: 105 ![]() ![]() ![]() |
me too incredible
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 798 ![]() ![]() ![]() |
I bought a cheap nice auto bag from Lidl, that fits exactly in that space… It won't move, as the boot floor is raised 4cm on the P400e. I also fitted an elastic band to keep the charging cable bag from occupying too much space. I don’t like the solution JLR found for the cable storage… And I can’t understand why the boot is not recessed on the left side too, there is A LOT of space that isn’t used at all over there… Just remove the left side panel and check for yourself!
pav911 Member Since: 28 Jul 2019 Location: Peterborough Posts: 23 ![]() ![]() |
There is actually an official LR part:
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3880 ![]() ![]() ![]() |
I did this cheap as chips.
