Home > In Car Electronics (L322) > Did all vogues in 2011 have dual screen or am I dumb?
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Retrofit
Can Dual View be retrofitted to a 2012 VSE without too much pain ? If it's just a case of swapping out the head units I'm happy to strip the dash down.
There's a lot of head units on eBay with slightly differing part numbers eg BH42-10E887-RG, AH42-10E887-RA.
Not sure what the difference is between BH and AH, although assuming the R is the model designation and A or H etc the firmware release. usually the later the better.
Post #713501 7th Mar 2025 5:59pm
JonnyCJ
After a couple of hours of googling, the one I need for my 2012 VSE is BH42-10E887-RG
Bit of a leap of faith to see if the wiring is the same, but if not, I’ll send it back.
Hopefully it’ll be a useful update for those looking to do the same.
The AH version appears to be the earlier 2009 version and the BH was manufactured in 2012, which matches my car build date.
Just need to work out how to strip down the dash to get at the old unit !
Post #713527 7th Mar 2025 9:58pm
you might find that the CCF will have to be adjusted as well ... ... - .- -.
Post #713530 7th Mar 2025 10:49pm
mjdronfield
https://www.fullfatrr.com/forum/topic55729...=dual+view
https://www.fullfatrr.com/forum/topic41810...=dual+view
Might be some info in these.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #713533 7th Mar 2025 11:18pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
When I've tried out dual view on mine, it says on the screen to press TV to switch to dual view which works very well. Not sure if others are the same.
Post #713592 8th Mar 2025 7:30pm
JonnyCJ
New dual view unit arrived today courtesy of eBay. The screen was typically smudged where fingers have worn away the "protective" coating. I've removed the outer frame, which is 6 small Philips screws and that's revealed the screen in its full entirety.
Some alcohol wipes and a bit of gentle rubbing and the rest of the protective coating has been removed, leaving a nice clean, clear screen.
I've ordered a matte finish, anti glare, iPad screen protector, so will cut that to size and fit and that should provide a much better finish than what was there originally.
Fitting the unit will be a few days away, as it's a dash strip down, but all proceeding to plan so far...
Post #713804 11th Mar 2025 4:35pm
JonnyCJ
An update...
Have a very helpful email exchange with Patrick at GAP. I asked the question on where to find the CCF to change to Dual View.
It transpires that it's not just a simple case of swapping out the complete head unit, you need to remove the screen from your old unit and install the dual view screen from a dual view head unit.
Configuring is then very simple using the search function in the Complete List on GAP IID. You do of course need to get access to the complete list from Patrick and the team, which I've done.
Further updates to follow !
Post #716649 23rd Apr 2025 4:02pm
