![]() | Home > Technical (L405) > L405 Brake line Failure |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Yep, that’s fubar.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1465 ![]() ![]() ![]() |
Evening northernmonkeyjones,
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1682 ![]() ![]() ![]() |
Yup new flexy needed, I would do both sides if I were you.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
What's really annoying is that JLR know the flexis are going to fail....
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1318 ![]() ![]() |
Actually for MY18 it’s not optional it is every 6 years! 2018 SE SDV8 4.4 Byron Blue |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 475 ![]() ![]() ![]() |
Its not uncommon unfortunately as they corrode around the banjo and pipe that runs along the suspension to the body, on the plus side they are easy to do, they come as a kit with two hoses and brake pipe in one. About £70 each ish if memory serves me right. If you DIY it and do both, when bleeding do the N/S first and bleed with the engine running that way you should be ok |
Thanks for all the responses Chaps,
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
Had the same problem at a complete perfect and rust free L405 from 2017 (exept only tank cover), the brake lines are corroded only at the rear axle.
I did my MY2017 preemptively in 2022 when I upgraded to the big brakes all round, the rears were tatty, the fronts passable but whilst it was all in bits, silly not to do the lot, one less thing to worry about. Covered the metal bits in Lanogard grease, and will continue to do so. Why oh why do LR use all those tinny little STEEL brackets and plain black painted screws? |
JamboM3 Member Since: 28 Jul 2021 Location: Berkshire Posts: 229 ![]() ![]() ![]() |
Just replaced all 4 of mine, weren't completely gone but would not have lasted another winter.
Thanks, I washed everything down straight away with lots of soapy water.
