![]() | Home > Maintenance & Mods (L322) > Removing Rusty 2010 Lower Tailgate Strap Cables |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 901 ![]() ![]() ![]() |
Whatever you do, don’t snap the head of the bolt off as the bolt screws into a blind thread welded on the inside of the panel - been there done that.
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 986 ![]() ![]() |
I undid mine with my pump pliers they came straight out with a bit of effort |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8518 ![]() ![]() ![]() |
As above, get all that rust off, squirt everyday for a week then I would use the Irwin nut removers in the link below, always had a lot of luck with them, find the size that just doesn't fit over the nut then press as hard as you can inwards while undoing it slowly...
Bought some stainless bolts... And replaced them... Much better.... If anyone else is as sad as me they are M8 x 40mm, change them one at a time and you won't have to realign the latch.. ![]() https://www.amazon.co.uk/Irwin-394001-Fast...amp;sr=8-6 https://www.amazon.co.uk/TG-02-corrosion-e...amp;sr=8-5 ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 34 ![]() ![]() ![]() |
I agree with JCW's comments. It may also be that the bolt has rusted into the eye boss and the eye boss is rusted to the panel and that s why its become an issue as the bolt head is not strong enough to turn both the bolt and eye? If you have a big hefty stillson type wrench that will grab into the eye that should give extra turning torque to undo the bolt a few degrees at a time. Not sure I've explained this very well! Current: 2003 TD6 HSE. 161,000 miles
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 900 ![]() ![]() ![]() |
Thank you, ordered, and I have been meaning to do this little job for ages ![]() |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 474 ![]() ![]() ![]() |
Mine were so long gone on my last Full Fat that I had no choice but to drill them out, meaning that the thread was also gone. I took the rear light off and did lots of prep on both sides to get rid of the rust then used a washer and a nut on the light fitting side to secure the new tailgate strap.
yorkshire-dave Member Since: 04 May 2024 Location: Yorkshire Posts: 4 ![]() ![]() ![]() |
Awesome thanks a lot guys. I won't get time to work on it till the weekend anyway so I'll give it a good spraying with penetrating oil every day in preparation.
