Home > Technical (L405) > Which Oil…..and a coolant rabbit hole….
kevinp
Just done my cooler mate and two of the plastic unions for the hoses snapped just while I was looking at it!! Hope yours goes well.
Post #713035 28th Feb 2025 9:24pm
goldeneye32
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
I've been using Patronas Syntium 5000 FJ from Opie Oils, I usually wait until they have a 15% off deal, always got a couple of oil services on hand.
Reckon I get 4-5K miles before the Service Required indicator comes up.
My Indy does a while you wait Oil and filter Service for me for about a £100, so with the oil in about £155-60.
If they didn't have the annoying electrical gremlins, they'd probably be the best cars in the world.......or is that Carlsberg!
(Sorry, you need to be a certain age to remember that lager commercial)
Post #713042 28th Feb 2025 9:33pm
Gremlin500
northernmonkeyjones wrote:
I’ve now gone down a coolant rabbit hole…….
Book says JLR.651.5003 or XLC. The only one I can find which directly says it’s that spec is Mannol AF12+
This is the approved one:
Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #713050 28th Feb 2025 10:43pm
Yep, got that 👍🏻 So that shows the Ford spec too….. WSS-M97B44-D but not the LR spec….
So I reckon anything have the Ford spec would be fine given it’s a Ford engine, Plenty of those about….. There is nothing that can't be fixed with a hammer😜😜
Post #713054 28th Feb 2025 11:38pm
Gremlin500
JLR recommended Coolant
It’s in the WM for both V6 and V8 engines:
Post #713063 1st Mar 2025 9:14am
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I use Halfords OAT. The amount I get through, I can't be spending a fortune on it.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #713064 1st Mar 2025 9:14am
