![]() | Home > Technical (L405) > Which Oil…..and a coolant rabbit hole…. |
BAZ8046 Member Since: 26 May 2023 Location: Chatham Posts: 29 ![]() ![]() ![]() |
I use Smith & Allen Momentum C1 5w30 for both the L322 & D4.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 484 ![]() ![]() ![]() |
snap used it on my l322 and also now on my l405 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8737 ![]() ![]() ![]() |
Will have a Google. |
Silverstone Member Since: 30 May 2024 Location: Silverstone Posts: 31 ![]() ![]() ![]() |
Changed the oil and filter in my MY2016 SDV8 and used Petronas Syntium 5000 FJ 5W-30. Purchased 10 litres from Opie Oils for £52.48 (incl delivery). "There is no replacement for displacement" - W O Bentley |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1306 ![]() ![]() |
@Silverstone +1 |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1160 ![]() ![]() ![]() |
And me for the above two. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1648 ![]() ![]() ![]() |
#3 for this one, it’s the right spec and the best value if you’re changing it twice a year as you probably should be, there’s really little point in using anything too expensive IMHO. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 214 ![]() ![]() |
Is there a 'bad' oil on sale any more? The days when we fretted over mineral oil being as viscous as water are long gone.
3 oil changes if you have a V6! Serious value! |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 137 ![]() ![]() ![]() |
I also use Smith and Allen. I use them for all my oils.
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 196 ![]() ![]() ![]() |
Plus another for smith and allen |
Ordered some smith and Allen. 👍🏻
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1290 ![]() ![]() ![]() |
I use Halfords OAT. |
Had some of that in the garage, needed a top up the other day, 1/2 a cup, but I’m going to drop some fluid out to do the cooler tomorrow, so basically a full swap.
