Home > Maintenance & Mods (L322) > Hood replacement won't open
smellslikeespresso
United Kingdom 2007 Range Rover Vogue SE Td6 Giverny Green
Hey folks!
Replaced the hood on my RHD 07 L322 with a hood from a LHD 08 L322.
Installation was no problem, eveything looked good and lined up.
I've now closed it and it won't open. I've pyulled the lever and the cable broke out of the end of the lever, when I pull on the cable with some pliers it still doensn't open and also doesn't have any give.
Any thoughts?
Post #712604 23rd Feb 2025 1:18pm
dingg1
It'll be slightly offset, you will need an assistant to pull the release cable, if you push the bonnet near the pegs which secure into the front panel you should be able to get them to release, try from the side of the bonnet also, hopefully you can get it sorted
Next time slacken the screws that hold the securing mechanism in the top of the front panel until its perfectly lined up and operating freely
Post #712607 23rd Feb 2025 1:45pm
smellslikeespresso
Ah, I had a bit of a play but I will go back with some more effort. There is some downwards movement when I push down around the pegs so I assume it just working that area?
Post #712620 23rd Feb 2025 5:25pm
mjdronfield
You need to try side to side I recon. Not had to do it but I don’t think up and down will help you… happy to be corrected though
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #712621 23rd Feb 2025 5:33pm
BAZ8046
Yes they are very sensitive to alignment.
Once you get it open if you put some grease on both sides of the fittings and then partly close it with some cardboard in between you can see where it makes contact.
It will just need adjusting so that the top pin sits in the centre of bottom catch.
Mine was badly adjusted when I got it and used to stick. 2012 TDV8 4.4 Westminster Santorini black
2016 Discovery 4 Landmark
2002 Defender TD5
Post #712640 23rd Feb 2025 9:22pm
