Home > Technical (L322) > Extra LED high beam install, 2007 tdv8
Henrik07
Norway 2007 Range Rover Vogue TDV8 Santorini Black
Hi all!
I have purchased a very clever front number plate frame with a 7800LM led bar integrated in it. I'm fitting it to my 2007 vogue. Does anyone know where it would be easy to tap into the high-beam-on signal? I.e. which harness to unwrap and colour code of the correct wire?
Kind regards,
Henrik
Post #711766 13th Feb 2025 9:28pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Is that the new Lazer Lamps Glide? Had been thinking about buying one.
Post #711795 14th Feb 2025 10:55am
Henrik07
It's made by someone called Strands. I believe it is a Swedish brand, so possibly not widely available in UK. Although it probably is, under a different brand name...
?si=sAreNb2HeDH4IZUz
Post #711801 14th Feb 2025 11:46am
a quick google came up with this,
https://www.kudauk.ltd.uk/product/strands-...te-led-bar
other UK companys probably do these.. ... - .- -.
Post #711802 14th Feb 2025 11:51am
Merchy
Nice product ,I would like one on my car, then I had a thought, would this be legal in the UK Question
As with the plate LED lights on, various traffic cameras that photograph the front of the car may not work properly. Thumbs Up Obviously I would never condone such actions Whistle Rolling with laughter
Post #711826 14th Feb 2025 5:19pm
Henrik07
Successfully installed. Makes a huge difference.
I pulled the RH headlamp and beeped my way from the high-beam bulb to the connector and identified two pins. Found my way to the corresponding two holes in the female connector on the harness and identified one as a permanent ground, which makes the other one a switched positive. This was a blue/yellow wire. Tapped into that for the switch signal. Works like a charm.
Post #712214 19th Feb 2025 1:05pm
