Home > Technical (L322) > most of 4.4 dash not working
zxrjohn14
United Kingdom 2004 Range Rover Vogue 4.4 V8 Barolo Black
I've found 3 diferent threads that have the exact same symptoms as mine, but it has never been followed through as to the answer to what is wrong
Dash comes on but:
No rev counter
Temp goes straight up too max
Speedonot working
Indicator tell tale not working (indicators work fine)
Yellow and red light in the bottom right corner (brake related)
Is it a bad earth?
Moisture?
Any advice appreciated
Thank you
John
Post #710985 3rd Feb 2025 11:05pm
zxrjohn14
if anyone has this problem in the future it is burnt chips or resistors on the board.
Another dash and Bob's your uncle.
Dash is not part of the security, so are plug and play
Post #711271 6th Feb 2025 9:52pm
Glad you got to the bottom of it... Thumbs Up Pete
Post #711297 7th Feb 2025 9:39am
D3Jon
That's good to know, I had an Audi A8 that required the dash to be coded, VAGCOM diagnostics couldn't do it from memory, so was a main dealer job... £££'s
I suppose your mileage will need to be corrected? Or when it comes time to sell, do you just sell the vehicle complete with the old set of clocks?
Would be interesting to know if GAP IID shows a difference in mileage between the instrument cluster and one of the other modules that stores mileage, or whether those other units just pull the mileage from the instrument cluster?
J 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #711300 7th Feb 2025 10:25am
zxrjohn14
the mileage in the dash will be just in the dash (i think) and modules will be recorded as to the mileage they have done... if they record mileage
Mileage can be changed a few different ways to suit the car.
Post #711344 7th Feb 2025 8:42pm
