![]() | Home > Maintenance & Mods (L405) > Ebay / Cheap fixed side steps |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
me..
Jamers Member Since: 12 Jan 2025 Location: Northern Ireland Posts: 12 ![]() ![]() |
I've just ordered a set, thanks Stan! |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2685 ![]() ![]() ![]() |
Ran a set on my old one no issues at all . |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 513 ![]() ![]() ![]() |
I have ones very similar on mine, the rivets will eventually give way and the silver trim starts to come off. It may be an idea when you art get them and before putting them on, to drill out the rivets and put self tapping screws in. Mine have been perfect since First time FFRR owner |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 220 ![]() ![]() ![]() |
Hi Jammers, when you take delivery of your new steps would you be able to post a picture of the mounting brackets that come with them? I would be very interested to see if they are the same as the ones in the picture, basically if they actually extend the jacking points. A lot of these after market steps come with quite flimsy mounting brackets that actually cover the jacking points and are unable to support jacking of the car. I have returned 3 different sets bought from flea bay for just this reason. If these are actually as advertised then I would like to try them myself. |
I certainly will. Expecting them to arrive by Thursday, watch this space! |
Received the side steps, photo of brackets attached.
Thanks for the update, can't see the pictures of the brackets though? _______________________________________________
Here's a link to my Google photos version of it instead: https://photos.app.goo.gl/cxcxgbwCd5SrwRtt5 |
Much appreciated so they are the more solid brackets that extend the jacking points, makes them a bargain |
Defo solid brackets....and you can easily jack up on them. ... - .- -.
chicb Member Since: 28 Nov 2019 Location: Dundee Posts: 105 ![]() ![]() ![]() |
Tip, before fitting, paint the underside with Hammerite or equivalent as they rust fairly quickly. |
And I see the price of the ones linked have now gone up by £37! Well, you snooze, you lose! I should have moved quicker! |
£170 with coupon code but there are out of stock..
