Home > Maintenance & Mods (L322) > 4.4 TDV8 Belt tensioner replacement
Page 5 of 5 <12345
bigben
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Just posting to confirm the accessory belt, water pump and tensioner can all be done without removing the fan and cowl.
The only realy pig being getting the tiny 8mm bolt back into the coolant pipe bracket.
The water pump was a little reluctant to come out but a few blows with some wood and a mallet made it move enough so the seal was cracked.
Car ran squeek free and more importantly coolant leak free afterwards.
(coolant leak symptom, as I couldn't find anything similar on here, was the car would be fine until it cooled down after a trip then it would leak a bit, this was the waterpump seal being OK on a warm engine but no good when it had cooled) 2011 TDV8 Vogue
2007 TDV8 Vogue
Post #704631 17th Nov 2024 10:50am
I’ve just done the tensioner on the 405…..
Was fiddlier that I remembered doing it on the 322. It’s still pretty straight forwards. It’s doable but frustrating and tighter than it looked.
I just took off the large turbo hose to the throttle body and you can get to all the bolts. Thumbs Up Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #710844 2nd Feb 2025 4:21pm
Page 5 of 5 <12345
