Home > For Sale & Wanted > [For Sale] L322 Trim Navy Boot/Floor Mat + NEW Varta Battery
tspd
Hi all,
Attempted to install a new battery in my L322 and accidentally ordered the wrong battery which will not fit my L322 S/C. It's a brand new Varta I1 Car Battery 12V Silver Dynamic. Link to the item I bought here:
https://www.ebay.co.uk/itm/394338639466
I've also bought new floors mats and a boot cover. These are still in fairly good knick so someone may want them. I have some various boot compartment trim parts as well.
Due to weight and size, collection from east London area please. Happy to drive to meet within reason.
Battery - looking for £90, boot and trim £40 all in. £120 for the lot or can sell separately.
Trim and boot will go in the bin if not sold within 2 weeks!
Thanks all.
 L322 2007 S/C 4.2L
First Full Fat!
Owner number 6
133k miles and counting
Buckingham Blue
Previous cars
'09 VW Fox
'15 VW Beetle GTI
'19 First Edition Velar
'22 XC90 II
'24 L322
Post #710257 26th Jan 2025 7:04pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
020 battery should fit the later cars but you have to Dremel off the bottom end foot ledges at the base of the battery because the base is about 3mm too wide at each end. It doesn't affect the battery itself. But it does give you next level battery capacity especially in AGM form.
Also the positive terminal you have to connect as you drop in the battery as there is little space for the fuse link to fit.
A.
 Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #710262 26th Jan 2025 7:37pm
tspd
Why I love this forum - so idiot beginners like me can learn Smile
Hold on the battery sale then but trim still up for grabs! L322 2007 S/C 4.2L
First Full Fat!
Owner number 6
Buckingham Blue
Previous cars
'09 VW Fox
'15 VW Beetle GTI
'22 XC90 II
'24 L322
Post #710266 26th Jan 2025 7:44pm
AndyRoo
I changed mine to an Exide 020 AGM a few weeks ago.
It's a snug fit and that 020 is damn heavy.
Example of the feet you have to dremel off, in yhe pic circled I think you may only need to do the right side one, but I did both ends just for a bit of extra wiggle room
A.
Post #710270 26th Jan 2025 7:52pm
tspd
Thanks. Presumably you ditched the metal retainer bits that screw and hold it in? L322 2007 S/C 4.2L
First Full Fat!
Owner number 6
Buckingham Blue
Previous cars
'09 VW Fox
'15 VW Beetle GTI
'22 XC90 II
'24 L322
Post #710272 26th Jan 2025 7:56pm
AndyRoo
Just modified them with the Dremel and a hammer to fit.
The battery front foot covers the threaded holes for the mounting, but just mark the holes location on the battery foot, pull it out, Dremel that with a grinding stone just enough to expose the hole and it should fit.
If the brackets prove too tough, you can omit them and use large penny washers bent slightly so they secure the base, just grind off part of the round edge to square off one side.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #710275 26th Jan 2025 8:07pm
bluebottle
United Kingdom 2012 Range Rover Vogue SE TDV8 Buckingham Blue
How much would you want for just the mats please? Assuming they're still available? 2012 L322 TDV8 Vogue SE: Buckingham Blue
2005 Defender TD5 110 XS: Cairns Blue - Gone but not forgotten
Post #710442 28th Jan 2025 3:48pm
tspd
£30 for just the mats mate, you can have the boot lid too if you want as doubt it will sell! L322 2007 S/C 4.2L
First Full Fat!
Owner number 6
Buckingham Blue
Previous cars
'09 VW Fox
'15 VW Beetle GTI
'22 XC90 II
'24 L322
Post #710458 28th Jan 2025 5:49pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Where in East London are you? PM if required. Interested in the boot trim / floor 👍
Regards
John
Post #710662 31st Jan 2025 12:45am
tspd
Haggerston, just off Kingsland Road Smile Thumbs Up L322 2007 S/C 4.2L
First Full Fat!
Owner number 6
Buckingham Blue
Previous cars
'09 VW Fox
'15 VW Beetle GTI
'22 XC90 II
'24 L322
Post #710675 31st Jan 2025 10:17am
tspd
RE battery - no longer for sale - because it fits! Thanks for the advice above. Simple dremel of the negative side feet so it’s flush and slides in. Tight fit but the clamps all work, and the fuse on positive is not damaged.
The trim, boot parts and carpets are still for sale.
Will be in Battersea RRLondon indy from Tuesday so please let me know if you want them before then. L322 2007 S/C 4.2L
First Full Fat!
Owner number 6
Buckingham Blue
Previous cars
'09 VW Fox
'15 VW Beetle GTI
'22 XC90 II
'24 L322
Post #710772 1st Feb 2025 4:56pm
