Home > Maintenance & Mods (L405) > Coolant leak - hose connection
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
Whilst doing a service, I noticed a coolant leak on the small pipe leading to the thermostat housing. It seems that the plastic hose connection has split.
I looked up the part number for a new hose on JLR Classic Parts (my VIN is FA211xxx) which is LR034629, £14.86, but no longer available.
The supercession takes me finally to LR080118, which is out of stock of course, and the price is now £176.90.
Best I can find aftermarket is
https://www.advancedfactors.co.uk/lr080118-coolant-hose which is £27.30 - seems to good to be true!
I'm concerned about whether the LR080118 part will actually fit - although it is only the plastic coupling that I am planning to use, I'll keep the existing hoses. It's a lot of money for a little plastic part.
Any thoughts?
Chris.
 L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #710217 26th Jan 2025 11:25am
ChrisJC
Well I can answer my own question. I bought the pattern LR080118 hose. Unfortunately the hose is smaller so the fitting at the end is not a straight swap.
To complicate matters, LR080118 as a T piece and a third leg going off which the original hose didn't have.
I decided to remove the extra hose and machine a plug to seal off the unwanted hose. Then I fitted the whole piece.
So far so good.
Old and new side by side:
Plug:
I do wonder what the Main Dealer would do if I had taken it there for a repair. Would it be parked up indefinitely?, or would they recommend writing the vehicle off?
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Post #710561 29th Jan 2025 7:38pm
andygts
Do away with the plastic push on fitting, the rubber hose slides straight onto the thermostat housing, I popped a boost hose on mine and in the process it smashed that connector. Free fix. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #710583 30th Jan 2025 8:51am
