Home > Maintenance & Mods (L322) > Texamatic ETL-7045E gearbox OIL
Pajeroboi
Hi all
I've ordered some texamatic ETL-7045E to service my GM gearbox but looks like I'm being messed around, or at least the delivery is going to be delayed.
I understand that the BMW equivalent is BMW 83 22 0 026 922?
Would someone confirm that is correct and does anyone have a link for either oil, ?
Many thanks Smile
2006 td6
Post #710532 29th Jan 2025 1:36pm
RRPhil
Texamatic 7045E was a Dexron III fluid, for which the GM licences expired in 2006, so that’s amazing if it is still available. GM moved users on to Dexron VI, but there is a potential issue in that its viscosity (new) is lower than that of Dexron III. Not necessarily a good thing if your valve blocks are worn, which is a particularly common issue with the 5L40-E! The justification is that the better shear stability of Dexron VI means the viscosity remains at its design specification for longer i.e. after a period of use it will be higher than ‘worn out’ Dexron III. I suspect that the BMW fluid that you mentioned is Dexron VI.
Someone on another forum asked if I thought a fluid called Texaco ATF HD 389 might be a more suitable alternative than Dexron VI. It has a kinematic viscosity of 7.1 mm²/s at 100⁰C and 34.9 mm²/s at 40⁰C. This compares to 7.4 & 33.8 for the original Texamatic 7045E fluid and 5.8 & 29.5 for Dexron VI so, on the face of it, it would seem a more suitable replacement for Dexron III than Dexron VI. Just my opinion, obviously.
Phil
Post #710539 29th Jan 2025 2:45pm
Pajeroboi
Hi Phil
Appreciate the quick response!
Yes that does seem like the best option and by your reasoning that makes complete sense. I intend on regularly changing the oil anyway, so will just use the Texaco ATF-HD 389 as id like to get this done asap as just purchased the RR (which is in mint condition aside from a pause when you pop it into D first thing in the morning Rolling Eyes ) and see if i can source some 7045e in the meantime.
Many thanks
Jim
Post #710544 29th Jan 2025 3:13pm
