![]() | Home > Technical (L405) > Possible Turbo issues |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
JCW - From Kevins post on page 2...
I can summise that it's main role is as you say to allow drain back of oil when changing the filter - but Kevin mentioned when his was missing, it flooded the air intake. Presumably while the engine is running. Given I'm losing loads of oil since the last service it had (where they most likely dislodged the bung or discarded it for some reason), but no noticeable white smoke, am i right in saying its likely to be going into the air intake and then collecting the second turbo. When I say a lot of oil... I put 9 ltrs in over a 4 month period after the service, checking and topping up regularly... still am This may not actually be the reason for the Restricted Performance but it sure doesn't mean the turbo needs replacing like the LR service centre advise... Ash ------------------------------------------------------ 2022 SDV8 AB 2016 TDV8 VSE 2011 TDV8 VSE 2006 V8 Vogue 2002 2.5 Vogue |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
Hopefully toby1 will come up trumps and you get it fitted and see what happens. |
I don't disagree Jonathan... maybe because the secondary turbo isn't spooling up (for other reasons) its just collecting there and then dripping out ... maybe.... Ash
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 231 ![]() ![]() |
Evening. Success. PM your address and I should be able to post it tomorrow as I have to walk into town to the barber. Hopefully I can find something suitable in which to put it.
Thank you Toby
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
The hole drains to the breather oil separator which is OK when the engine isn't running but when running the continual flow of oil floods the separator causing oil to be blown out with the air, thereby entering the inlet. |
Good explanation Graeme. Makes sense.
It wasn't my finding, but I couldn't hassle myself to find the original poster. |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 69 ![]() ![]() ![]() |
As I recall, the purpose of this device is to allow oil to drain from the filter housing when the filter element is removed. I think another forum member, maybe jay gee, solved the problem by blanking the hole off with a self tapping screw. |
ashtrucker Member Since: 30 Jan 2012 Location: lincoln Posts: 48 ![]() ![]() ![]() |
Dose anybody know where you can get that leaf spring from 2012 Westminster 4.4 tdv8 |
I've just ordered a new cooler so if anybody wants the part out of my old cooler you can have it. Won't be for a few weeks yet though. |
Just sent you pm 2012 Westminster 4.4 tdv8 |
Hi Toby,
Let's not throw up the bunting just yet, but I am looking forward to developments.
