Home > Technical (L322) > 4.4 TDV8 cut out after blowing smoke would not restat
cornish bob
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Good morning ,yesterday I had a problem with my 4.4 TDV8 I pulled out from a slip road ,accelerated quite hard saw plumes of grey smoke, the car then died got a restricted performance message up managed to get to the side of the road tried to restart nothing plugged my Gap tool in which showed no faults tried several times to restart it but it cranked but did not start after a lengthy wait I was recovered home, I sat in the car as it rolled off the transporter had my foot on the brake turned on the ignition and it started right up ,it did have a rough idle and stunk of unburnt diesel so i'm now wondering where to look regarding the rough idle, I've not been out in it yet as I don't want a repeat of yesterday can you guys pointt me in the right direction to look many thanks Bob
Post #710415 28th Jan 2025 10:21am
GraemeS
Do you periodically accelerate hard and therefore the smoke is unusual or do you almost never which would allow oil accumulation in the secondary turbo's inlet tract?
Post #710474 28th Jan 2025 8:15pm
cornish bob
Hi no, I very rarely accelerate hard enough to use the kickdown as I nearly always have my dogs in the car or I am towing a trailer ,I pulled the MAP sensor out yesterday and it was completely choked up so I think my next move will be to take the manifold off to give it a clean up and check, there is a suspicious drip of oil from underneath the manifold on the left hand front coupler, thank you for your reply
Post #710504 29th Jan 2025 10:26am
cornish bob
I pulled the doughnut intake off today which was choked with oily carbon deposits clean it out and refitted ,but noticed oil running down the intake pipe to the r/h turbo , when I took the elbow from the r/h air filter there was oil in the pipe which runs down to the turbo ,so am I looking at a faulty turbo? ,it doesn't look too doable from underneath
Post #710609 30th Jan 2025 5:59pm
GraemeS
Right hand when looking at the engine from in front of the vehicle or when in the vehicle looking forwards? When looking forwards the RH turbo is the primary turbo.
There will always be traces of oil in the intakes but if excessive then something isn't right. However a failed turbo is unlikely to be the cause.
Post #710619 30th Jan 2025 8:14pm
cornish bob
Hi Grahame yes right hand side when standing in front of the vehicle,if not the turbo what could it be? been reading stuff about secondary drain mods etc ,the pictures don't really show how oily it is' Could it be a matter of just really giving it a bit of stick now and again
Post #710625 30th Jan 2025 8:38pm
GraemeS
Because the 2nd turbo isn't full-time, the valves used to shut-off its air intake and to prevent exhaust going through it need to be exercised occasionally to keep them working and to clear small quantities of accumulated oil, sticking the boot in now and then is necessary.
Post #710635 30th Jan 2025 9:30pm
cornish bob
Hi I removed the valve from the second turbo It was full of oil, the intake from the filter to the turbo also has a lot of oil in it but I cannot see a way of removing it,the jubilee clip from the convoluted pipe is inaccessible , I can see some nuts holding a duct on what I assume is the turbo but doesn't look any easier to get too, I assume that the subframe will need to be dropped to gain access to the turbo
Post #710750 1st Feb 2025 11:38am
GraemeS
Don't bother to cleanout the oil residue as it will soon clear when whatever is causing oil build-up is fixed.
Have a read of the recent thread about a possible turbo failure and excessive oil in the inlet tracts which was caused by a missing oil filter housing drain plug. Check the plug in your filter housing to see if it is still fitted.
Post #710787 1st Feb 2025 7:36pm
cornish bob
Thanks Grahame ,I'll check it this morning
Post #710826 2nd Feb 2025 11:15am
cornish bob
Checked the valve in the oil filter all looked ok but on closer inspection saw that as the filter had been screwed back on it had slewed the spring slightly moving out of alignment with the drain hole think it was done by the oil filter, it looked different to the Mahler one anyway buttoned it all up refilled it with oil went for a run, got a full DPF message but after a run up the M2 it cleared the message ,no warning lights no smoke so its got a reprieve for a while ,going to try and get my classic sorted now so I'll have a more comfortable plan B in case it happens again ,although my series 3 got me about ok
Post #710864 2nd Feb 2025 6:35pm
