![]() | Home > Maintenance & Mods (L405) > L405 door speaker upgrade |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 358 ![]() ![]() ![]() |
Where does this go in the car?
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 791 ![]() ![]() ![]() |
This is the basic system speaker placement
That is going under the front seat. This is how a similar one is removed in an Evoque: And in a Sport: |
You appear to be correct thank you. I am trying to establish where the sub is on a 2013 L405 with the mid range 825w system. |
This should be the definitive answer at last!
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1578 ![]() ![]() ![]() |
Yes, there’s a lot of mixed opinions on the systems. Now I know where the sub should be I need to check and see if it’s actually working.. |
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 130 ![]() ![]() ![]() |
I started of with the 380w system which was not good, i changed the amp under the passenger seat to the 825w amp then used the IID tool to update the system to the 825w system which then gave me the 4 sound settings which made a huge difference, then i changed all the speakers to the signature carbon speakers in all 4 doors and the signiture subwoofer under the drivers seat and with the upgrade i could also add the speakers which were missing in the center of the dash and the shelf speakers which were missing in the luggage area. It made a huge difference. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7853 ![]() ![]() ![]() |
I’ve got like 7 old LINN boxes in the house to entertain me music wise. Will def be looking for the signature system if I go L405. See it’s available in the Sport too…. Will wash my mouth out 🤣.
@MJD:
Ok, I believe the sub should be under the drivers seat but I can’t see it, hear it, or feel it under there. The L322 had the sub in the side panel in the boot and I am wondering whether early L405’s like mine did too.
