![]() | Home > Technical (L405) > Possible Turbo issues |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 231 ![]() ![]() |
I've recently changed mine and you are welcome to it from the old cooler. I assume it is the same part on both 405 and 322. 2012 Vogue TDV8 in Aintree green over sand |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
Thank you Toby.
James W Member Since: 29 Nov 2009 Location: Riyadh Posts: 295 ![]() ![]() ![]() |
Sorry if this has been covered but have you checked whether you have had the oil sensor loom recall done? I had restricted performance when the 2nd turbo kicked in until I had the mod done at an independent (despite LR saying it had been done, when it hadn't). By the time I fixed it, I needed a new turbo actuator module which had been damaged by the oil. Fixed the problem completely. Details: https://www.fullfatrr.com/forum/post695459.html#695459 Service Instruction: https://www.fullfatrr.com/gallery/albums/userpics/10080/N357.pdf FFRR SDV8 Autobiography |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
Don't know whether you saw my other message to make sure the plastic basket is in place that goes inside the filter.
I have the cooler and the part required but it is not apparent how I remove it from the cooler. I don't want to break it. There appears to be a push clip at 4 o'clock for want of a better word. Does it just pull up? 2012 Vogue TDV8 in Aintree green over sand |
You need to gently bend the four tangs up a little with a sharp pick just enough for it to release.
OK, thanks. I have a small-ish pick so will attempt tomorrow. I've had a bit too much red wine to try tonight |
It's trickier than I expected. I have not removed it yet. Should it have a black bung in the middle as it is hollow?
Hi Toby
Hi Kevin,
Don't worry about the questions Ash.
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 901 ![]() ![]() ![]() |
Is the rubber bung only there to allow oil in the filter housing to drain back into the sump when unscrewing the filter so that oil doesn’t spill out everywhere when doing a filter change?
JCW, I think the main function of the bung is to drain the filter.
