![]() | Home > General (L405) > TDV6/SDV6 vs D300 |
l322novice Member Since: 15 Jan 2016 Location: South Posts: 32 ![]() ![]() ![]() |
Hi all and apologies if this has already been discussed and answered. Been without a Range Rover for too long now and pondering what to splash out on if the horses come in. What is the consensus, a nice late-ish low mileage L405 V6 diesel (either TD or SD) or an early Ingenuim L405 D300?
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2610 ![]() ![]() |
Definitely D300/350. |
Thanks Phillip. Are they that much better? |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 924 ![]() ![]() |
I've always had V6 3L engines and the latest D300MHEW is brilliant. It's smooth, quick, economical and quiet. At more than Ā£6k under the D350 it's great value and unless I was towing I wouldn't have anything else. All LR cars from 1984
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8737 ![]() ![]() ![]() |
Iāve got the D300 in the disco and it is a lovely smooth engine. Definitely worth looking at, but make sure itās serviced regularly. There is nothing that can't be fixed with a hammeršš
DaveBL405 Member Since: 26 Sep 2024 Location: Hampshire Posts: 27 ![]() ![]() ![]() |
What mpg do you get out of interest? |
The true mpg(not what the car says!), for the D300 in my car (which is mostly under 20 mile trips), is 30.7. True mpg on long motorway trips is about 38 All LR cars from 1984
What was the car reading for mpg then?
Anything from 4 to 5 mpg more |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1648 ![]() ![]() ![]() |
Interesting.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2629 ![]() ![]() |
Is the MY21.5 L405 D300/D350 MHEV? If it is then it's off my list. |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1456 ![]() ![]() |
All D300/D350 are MHEV and, I believe, so are the petrol Ingenium variants (but not the V8 petrols). 2021 D350 Fifty Edition - Carpathian Grey
Thanks. I was starting to suspect they are.
No chance a mild hybrid is going to be much more economical, let alone a third better - the battery is tiny and it never actually runs only on electric. |
