![]() | Home > Maintenance & Mods (L405) > 2020 Deployable step obstruction on deployment |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1635 ![]() ![]() ![]() |
Hi Fez, yeah this problem is very common, search “deployable steps” above and read on, & on, & on…
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3210 ![]() ![]() ![]() |
anyone know how to disable the steps in a L405? I'm off to the snow and prefer them not to get dunked up.
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 276 ![]() ![]() ![]() |
Yep, that's the one. Get in the car and close door so steps retract, then press and hold the button in before switching ignition on, switch ignition on and it should flash a few times to indicate the steps are disabled. Repeat same procedure to re-enable. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
fez Member Since: 24 Jan 2025 Location: UK Posts: 3 ![]() ![]() ![]() |
Quick question does any one have the steps for removing the steps, so I can remove the hinges, want to make sure I only remove what I need in the right way. Looks like I need to remove some of the panels but just want to check before I start just pulling on pieces |
Some one mentioned I should also disconnect the battery for 10 minutes to reset the steps, is that correct?
