Home > Technical (L322) > Jump starting a 3.6 (New issue !)
Maybe one of these ?
https://www.fullfatrr.com/forum/topic40178.html
https://www.fullfatrr.com/forum/topic58383.html
https://www.fullfatrr.com/forum/topic64721.html
https://www.fullfatrr.com/forum/topic64774.html
https://www.fullfatrr.com/forum/topic63320.html
https://www.fullfatrr.com/forum/topic63172.html
Post #709997 23rd Jan 2025 7:19pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Thanks Alistair, I will try these options, I have a feeling that as it is sat on an incline the gearbox is 'locked' maybe an old skool thought, so will give it a nudge tomorrow with the 405 Bow down 2013 L405 Autobiography Baltic Blue
2007 L322 Vogue Buckingham Blue
Post #709998 23rd Jan 2025 7:28pm
sako243
If you ensure the vehicle is secured safely (chock the wheels etc.,) then you should be able to put the box into neutral. I can't remember if it's the same on the 3.6s but I had to do it a couple of winters ago with my 4.4 when I blew up the rear propshaft.
Lift the cup-holders out of the centre-console and there's a little flap you can remove, there's then a red flag / tag that you can pull to put the box into neutral. I have a feeling on the 3.6 which has the 6HP it might be accessed via the side but I might be wrong. Ed
Post #710044 24th Jan 2025 12:32pm
