Home > Technical (L405) > Possible Turbo issues
Page 3 of 8 <12345678>
GraemeS
Australia
Thanks and I agree with your thinking.
Post #709846 21st Jan 2025 9:25pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Update: LR suggest they cleaned the inlet pipe to the turbo, took it out for a test drive and there is now more oil in the turbo inlet pipe. No idea if that means anything but I know its losing oil - He says its defo the turbo....
<edit> - Having thought about that - if the oil is in the inlet pipe surely it didn't come from the turbo... Its before it reaches said turbo presumably?
He has said the modified filter pipes are all fine...
He then went on to say he can prbabky source a Garett Turbo which will likely be cheaper than a LR branded part..... Not sure he'd be allowed to do that would he?
Any views
Anyway - He has agreed for me top pick the car up tomorrow 'as I need it for the weekend'... and it might not be going back to them Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #709908 22nd Jan 2025 5:47pm
GraemeS
Australia
What modified filter pipes?
Post #709917 22nd Jan 2025 8:33pm
comports
Apparently there was a design change fitted from late 2014 models. Twin tubes was it.?
That’s what he said anyway - not sure I believe much of what I’m being told Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #709922 22nd Jan 2025 8:54pm
kevinp
I think they mean the oil drain mod possibly.
Post #709926 22nd Jan 2025 9:40pm
GraemeS
Australia
A 2016 model would already have a factory-fitted secondary turbo dual drain so they shouldn't be making any reference to that modification. Do they really know what they're doing?
Post #709932 22nd Jan 2025 11:06pm
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
When I first purchased my L322 4.4 tdv8, I had the same restricted performance issue when exceeding 2400 rpm. Having replaced all relevant inlet hoses, and checked that the CSOV valve operated ok, I came to the conclusion that it must be a problem with turbine shut off valve on the left hand turbo ,because no matter how hard I pushed the engine, the left exhaust front pipe was still cold.
The shut of valve, unlike on some turbos is a vacuum operated sliding spool with ports in it. If the turbo is never used, usually by a very elderly driver, as was the case with my vehicle prior to my ownership, i think carbon builds up around the valve and prevents it sliding.
I cured mine, by connecting a hand operated vacuum pump to the vacuum pipe which I disconnected from the valve at the front of the engine. I kept pumping the vacuum as high as it would go, and then quickly released it, I also tapped on the valve with a small hammer. Eventually after a number of attempts at pumping the vacuum and releasing it I could hear a slight clunk as the valve closed.
Needless to say I have never had the restricted performance issue since. As others on the forum have pointed out, it is a good idea to routinely work the engine hard enough to operate the valve to prevent it sticking. There was also quite a bit of oil contamination on the junction of the down pipe to the turbo which has now burned off.
Post #709934 22nd Jan 2025 11:58pm
toby1
Sadly Graeme, this is typical of the motor trade in this country.
Sure, there is the odd garage with a proper, experienced diagnostic technician that knows what he's doing, but you have to bear in mind that most are just a 'fitter' (remove/replace).
Most competent driveway DIYers are not that far off the typical fitter in a workshop, except they're not chasing bonus to put bread on the table.
The OP is at their mercy as he is unable/unwilling to have a go and that is the unfortunate aspect.
I like the sound of Dtech's idea, personally. 2012 Vogue TDV8 in Aintree green over sand
Post #709949 23rd Jan 2025 9:35am
comports
Thanks Toby
I am 'willing' to have a go but not sure I have the knowledge to do so.. However.... I went to pick the car up today as I 'need it for the weekend'
They charged me for 3 hours labour (bearing in mind they've had the car for 10 days) and 3 days Loan car costs - total bill was £522.
He has also told me that they can source a Garrett Turbo instead of a LR badged one for £1,400 instead of LRs £2,200 - I've asked him to email me the details to think about.
On the way home... about 5 miles from leaving the garage I git the engine management light up on the dash - Plugged in IID and read the following ..
Turned round and went back to them to advise of this new issue - they looked a little baffled. I had a quick google while stood next to them that lead me to the Topix page on the error and showed the 'fitter' - He followed the Topix guidelines and Primed the sytem and then reset as decscribed - reset the codes and it was all ok. I'm not sure how much of a road test they actually did on my car....
Which leads me onto this.. The work they say they carried out.
Maybe I'm wrong but there is no mention of checking / testing the CSOV... no mention of checking any oil drain pipes etc...
The invoice also lists the "mileage in" as 82857 and the 'mileage out' as 82858 - Not sure they did a very long road test given they are on an industrial estate with no dual carriageways close by.
The more I think these things through the more i am set on not taking it back to them... however I am now almost £1,000 down and still no realistic cause of the issue Big Cry
I have now reminded myself how damn nice the car is to drive and be in though... Laughing Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #709989 23rd Jan 2025 6:12pm
That all looks a bit suspect, I know what I would do and that's have a nice drive to see Craig at Cam Tech, you will get an excellent service and a fair price.... Thumbs Up Pete
Post #709996 23rd Jan 2025 7:10pm
toby1
Yes, it's a Censored situation. In the perfect world, 3 garages would diagnose the same issue, correctly and accurately.
On the plus side, if there is one, it is driveable below 2,500 RPM so comports can take it to (yet) another garage should he so wish.
I wish you the best, comports, and I hope you have it sorted within a reasonable time and cost. 2012 Vogue TDV8 in Aintree green over sand
Post #710001 23rd Jan 2025 7:34pm
comports
Thank you all gents.
Your advice and guidance has been amazing and invaluable Bow down
I’ll find out where Mr Craig is located and see if I can make that work - if he’s accepting of my booking 😁
I’ve managed to drive it for 9 months like this after the first let down so it’s not desperate - other than the amount of oil it seems to be getting through now. I’ll try to find a workshop manual to point me to these pipes that may not be seated correctly if the weather warms up a tad. Wondering if I can stick it in extended height in my garage, drop the under tray and see if I can see anything, but jobs like these are so much easier when one has a ramp..!
Onwards for now….
Thanks again all Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #710008 23rd Jan 2025 9:15pm
Ash, Mr Craig is located just off the M5 just south of Gloucester……
So a good trip to the Cotswolds might be in order.
It sounds like yours is doing what the 322s used to do before they introduced the turbo drain mod. 🤷‍♂️
First port of call if it was me, would be to try and free up the sticky secondary turbo actuator to see if it can be made to work again. From memory of the system (on the 322) it’s a solenoid valve and should be at the front of the engine and is the same on 405.
If it the actuator which has failed rather than the valve it’s available as a repair kit LR033284. Which is about £100….
Start with the cheap and work up.
 There is nothing that can't be fixed with a hammer😜😜
Post #710021 23rd Jan 2025 11:09pm
kevinp
Ash, just undo your filter and have a look at the drain back valve, if only for my sanity.
Laughing
Post #710025 23rd Jan 2025 11:38pm
comports
Thanks NMJ
I’ll take a look at that this weekend if I can - I presume its easy to get to without dismantling too much but will check.
Thanks also Kevin
Again, will take a look and, assuming I can find it, will have a ‘fiddle’ whilst I’m out there.
I suspect the 2 issues are separate but both need fixing. Losing the oil is probably more urgent !
Will post back when once I’ve had chance to look at the above. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #710043 24th Jan 2025 12:17pm
