![]() | Home > Technical (L405) > Possible Turbo issues |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2551 ![]() ![]() ![]() |
Thanks and I agree with your thinking. |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1746 ![]() ![]() ![]() |
Update: LR suggest they cleaned the inlet pipe to the turbo, took it out for a test drive and there is now more oil in the turbo inlet pipe. No idea if that means anything but I know its losing oil - He says its defo the turbo....
What modified filter pipes? |
Apparently there was a design change fitted from late 2014 models. Twin tubes was it.?
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1258 ![]() ![]() ![]() |
I think they mean the oil drain mod possibly. |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 65 ![]() ![]() ![]() |
When I first purchased my L322 4.4 tdv8, I had the same restricted performance issue when exceeding 2400 rpm. Having replaced all relevant inlet hoses, and checked that the CSOV valve operated ok, I came to the conclusion that it must be a problem with turbine shut off valve on the left hand turbo ,because no matter how hard I pushed the engine, the left exhaust front pipe was still cold.
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 184 ![]() ![]() |
Sadly Graeme, this is typical of the motor trade in this country. Sure, there is the odd garage with a proper, experienced diagnostic technician that knows what he's doing, but you have to bear in mind that most are just a 'fitter' (remove/replace). Most competent driveway DIYers are not that far off the typical fitter in a workshop, except they're not chasing bonus to put bread on the table. The OP is at their mercy as he is unable/unwilling to have a go and that is the unfortunate aspect. I like the sound of Dtech's idea, personally. 2012 Vogue TDV8 in Aintree green over sand |
Thanks Toby
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8349 ![]() ![]() ![]() |
That all looks a bit suspect, I know what I would do and that's have a nice drive to see Craig at Cam Tech, you will get an excellent service and a fair price.... |
Yes, it's a |
Thank you all gents.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8673 ![]() ![]() ![]() |
Ash, Mr Craig is located just off the M5 just south of Gloucester……
Ash, just undo your filter and have a look at the drain back valve, if only for my sanity.
Thanks NMJ
