![]() | Home > Technical (L405) > Auxiliary reverse light. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
From the Workshop manual available for free download in the WIKI....
dave the builder Member Since: 12 Nov 2024 Location: North Wales Posts: 36 ![]() ![]() ![]() |
Many thanks. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
You in theory have a reverse light cable behind the rear bumper on the towing connectors where you would plug in the towing electric kit. There is nothing that can't be fixed with a hammer😜😜
Hi thanks, I have the pull off panel, which is where I plan on putting the light but don't have a towbar. I haven't looked as yet but are you saying the wiring would be there incase I wanted a towbar ? If so what colour would I use ? Cheers |
Yes the wiring should be there clipped up behind the crash bar.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1687 ![]() ![]() ![]() |
@OP,
Thanks. Looked inside today and there is two connectors which I assume are for the towbar harness. As you say will look to see which was works when reverse is engaged. |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 299 ![]() ![]() ![]() |
On the 13 pin reverse is pin 8 (pink) and ground is pin 3 (white)
Thanks |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
You have tried upgrading the standard bulbs? Cheers
Just had a look. Thought I might have the old towing wiring I just swapped out as the socket was broken. But it looks like I chucked it out.
