Home > Maintenance & Mods (L322) > Auxiliary heater location 2012 L322 tdv8 |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3185 |
It should be on the pax side rear of the engine bay. access normally involves removing the inner wheel arch cover IIRC.
17th Jan 2025 12:11pm |
Bazzer58 Member Since: 18 Oct 2024 Location: Cornwall Posts: 3 |
Thanks. I will try and find it.
17th Jan 2025 1:14pm |
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 115 |
That's where mine was. Relatively easy to get to though getting the liner off is a bit of a pain. Pretty obvious once you get access, its at the rear of the wheel well, is a relatively small bx with a long exhaust hose out of it pointing down. |
17th Jan 2025 2:58pm |
ashtrucker Member Since: 30 Jan 2012 Location: lincoln Posts: 34 |
Sorry wrong section 2012 Westminster 4.4 tdv8 |
17th Jan 2025 3:40pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7840 |
This is a pic from the Wiki about brake line replacement on a TD6…. Gives you an idea of location though….
17th Jan 2025 5:46pm |
s.m. Member Since: 21 Feb 2016 Location: Sarajevo Posts: 7 |
Auxilary heater on 4.4 tdv8, 2012 is behind front right wheel arch (lhd)
20th Jan 2025 5:12pm |
