Home > Maintenance & Mods (L322) > Auxiliary heater location 2012 L322 tdv8
Bazzer58
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Zambezi Silver
Can anyone point me in the correct location for the auxiliary heater. I can’t see it under the bonnet! Mind you, with that sized engine it is difficult to see anything. It is an L322 tdv8 2012 one of the last with the 8 speed box. Just before the L405 took over.
Thanks.
Post #709416 17th Jan 2025 12:07pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
It should be on the pax side rear of the engine bay. access normally involves removing the inner wheel arch cover IIRC.
see MJdronfield's diagram in this thread.
https://www.fullfatrr.com/forum/post609004.html
Post #709418 17th Jan 2025 12:11pm
Bazzer58
Thanks. I will try and find it.
Cheers
Post #709427 17th Jan 2025 1:14pm
RobsterPC
That's where mine was. Relatively easy to get to though getting the liner off is a bit of a pain. Pretty obvious once you get access, its at the rear of the wheel well, is a relatively small bx with a long exhaust hose out of it pointing down.
Post #709446 17th Jan 2025 2:58pm
ashtrucker
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Sorry wrong section 2012 Westminster 4.4 tdv8
Post #709450 17th Jan 2025 3:40pm
mjdronfield
This is a pic from the Wiki about brake line replacement on a TD6…. Gives you an idea of location though….
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #709476 17th Jan 2025 5:46pm
