![]() | Home > My Range Rover > New Member & New L322 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35597 ![]() ![]() |
welcome Sam to the forum and wiki... |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 223 ![]() ![]() |
Congratulations. 2012 Vogue TDV8 in Aintree green over sand |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
Welcome.
Sam P Member Since: 20 Jan 2025 Location: Derbyshire Posts: 5 ![]() ![]() ![]() |
Hi All
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 900 ![]() ![]() ![]() |
No need to drill holes, which would probably promote more corrosion in any case, just remove the central number plate light / switch panel (a few torx screws) and you can spray inside the tailgate using a straw type attachment on your spray can / gun.
Great advice. I’ll do that. Many thanks!!! |
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 110 ![]() ![]() ![]() |
Dynax S50 for cavities and Dynax UC (clear) or UB (brown) for underbody stuff is much better than Lanoguard. You can apply them with 600mm nozzles to get in all those nooks and crannies. S50 in particular is perfect for sills and inside subframe tubes.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 899 ![]() ![]() ![]() |
I have sprayed Dinitrol RC900 rust converter into my tailgate ( I removed the tailgate lights to access the area ) , I had my lower tailgate open with old rags and towels placed on it to catch the drips coming out of the drain holes Am about to do a second spray this afternoon, as it is a bit warmer But a question, before I use the Dinitrol ML Brown cavity wax one evening this week, Thursday looks to be even warmer, surely the cavity wax will block the drain holes - will it not ? And does anyone know what purpose the drain holes have, I cannot see the point of them, was it just a design error when they made the tailgates, or a carry on from previous models perhaps ? How does water get in at the top of the tailgate to then drain out of the drain holes ? Obviously I don't want to block the drain holes if they have a purpose, but then I have read on many forums that people have used cavity wax inside the tailgate after they used some rust converter. |
deleted |
Not sure how thick the cavity wax is, but the holes will just be a hole in the metal, so once it’s all set, just poke something up the hole if you think it’s going to be blocked. Doesn’t need too much thought, aside from what you’ve already considered, which is catching the drips ! |
I might machine two pieces of wood cut to the drain hole size and poke it in, before I do the cavity wax, I still cannot fathom out the purpose of the drain holes, I mean we are calling them "drain holes" for no apparent reason than that is what they look like to us, but I question the real purpose for them ? |
SeldomSeenKid Member Since: 24 Jan 2024 Location: Glasgow Posts: 73 ![]() ![]() ![]() |
I think they are actually drain holes for when the car was dipped in anti corrosion zinc phosphate solution at the factory. ---------------------------------
good thinking batman - yes that makes sense |
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 50 ![]() ![]() ![]() |
It gasses out over the next 1-2 weeks to a thin film, so you should be ok, and as you say they’re not there for drain holes anyway. |
