![]() | Home > Technical (L322) > Vacuum lines 4.4 tdv8 l322 |
Wish Member Since: 17 Jan 2025 Location: Riemst Posts: 22 ![]() ![]() ![]() |
Btw its solenoid B . The one near the belt.
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 415 ![]() ![]() ![]() |
to help a little bit
Thank you,
is it the solenoid near the vacuum pump or the other side? Its actually a sport |
This on here |
This one |
This one
i replaced my pipes a year or two ago, lemme see if i can find my post about it and any pictures i might have
Thanks, did you replace also the hard lines or only the rubber ones? |
Ok, thx good picture. 👍
no the metal plate just above it and whatever else was in the way really.
Ok thank you very mutch |
the pipes/solenoid are on a backing plate
Do you mean lose these screws? |
