Home > Technical (L322) > Vacuum lines 4.4 tdv8 l322
Wish
Belgium 2011 Range Rover Vogue 4.4 V8 Java Black
Hello,
I bought a l322 4.4 tdv8.
I have a fault code P004B-71.
I noticed i have multiple loose vacuum connection around the solenoids.
The 2 plastic lines that come from the top are not connected.
Does anyone has a picture of how they are connected? Or a diagram?
Im not sure where wat goes.
Thanks and greetings from belgium 😇
Post #709516 18th Jan 2025 9:42am
Wish
Btw its solenoid B . The one near the belt.
Greetings
Post #709517 18th Jan 2025 9:43am
mgrover
to help a little bit
https://www.fullfatrr.com/forum/topic63511-30.html Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #709526 18th Jan 2025 11:28am
Wish
Thank you,
I just find it hard to see under what is the fuel pump i think 😅
Post #709527 18th Jan 2025 11:32am
mgrover
is it the solenoid near the vacuum pump or the other side? Its actually a sport Sad
Post #709528 18th Jan 2025 11:33am
Wish
This on here
Post #709529 18th Jan 2025 11:37am
Wish
This one
Post #709530 18th Jan 2025 11:38am
Wish
This one
Post #709531 18th Jan 2025 11:38am
mgrover
i replaced my pipes a year or two ago, lemme see if i can find my post about it and any pictures i might have
here you go
https://photos.app.goo.gl/W5JawRg88heDFLT98
not my pic Its actually a sport Sad
Post #709532 18th Jan 2025 11:40am
Wish
Thanks, did you replace also the hard lines or only the rubber ones?
Post #709533 18th Jan 2025 11:40am
Wish
Ok, thx good picture. 👍
What did you remove to access it? The fan?
Post #709534 18th Jan 2025 11:46am
mgrover
no the metal plate just above it and whatever else was in the way really.
i used some silicone lines, let me find my post about it since it was some specific sizes
ah its on here
Post #709539 18th Jan 2025 1:08pm
Wish
Ok thank you very mutch
Post #709545 18th Jan 2025 2:19pm
mgrover
the pipes/solenoid are on a backing plate
so you can unscrew that and lift as 1 piece.
if theres been an oil leak id also recommend using lots of degreaser to while activating the solenoid to clean it out. Its actually a sport Sad
Post #709550 18th Jan 2025 3:18pm
Wish
Do you mean lose these screws?
Post #709560 18th Jan 2025 4:58pm
