Home > Technical (L405) > Fuel burning heater help l405 |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 496 |
it wont come on if the fuel level is below a certain amount, for if the battery isnt in tiptop charge. First time FFRR owner |
16th Jan 2025 12:53pm |
Pablo398 Member Since: 31 Dec 2023 Location: Wales Posts: 29 |
Yeh sorry forgot to mention battery fully charged and full tank. |
16th Jan 2025 12:57pm |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 248 |
It also only comes on once between engine starts, so if you had bene playing with it prior to today it would disable it, assuming the engine hadn't been started in the period.
16th Jan 2025 1:15pm |
Yeh started and moved it yesterday after it was working. Also went for a good drive today to check that was not the issue. |
16th Jan 2025 1:18pm |
Error codes now attached |
16th Jan 2025 2:04pm |
16th Jan 2025 2:07pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1738 |
Does it only function below a certain temperature..? I thought it was 4 degrees? Ash
16th Jan 2025 2:42pm |
Yes it was -1 this morning. And about 2 deg when I went for a drive and tried again. I can clear the fault codes but they keep coming back. |
16th Jan 2025 2:48pm |
If I need to tackle these 1 by 1 is the auxiliary heater control module the one that the remote operates in the boot or is there another module? And are the flame sensor and overheat sensor just part of the burner or can they be fixed? Just strange I had no fault codes after changing the pump and all working now these faults. |
16th Jan 2025 5:46pm |
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 90 |
All those faults are in the FBH. It has its own ECU.
16th Jan 2025 6:48pm |
Thanks so do you think it could just be a fuse? If so do you happen to know which one? Or more than likely a replacement heater. |
16th Jan 2025 6:51pm |
I don't think it's the fuse for you. In my experience that would give you a B129A-88 code (LIN Bus "D" - Bus off).
16th Jan 2025 7:40pm |
Thanks will have a check anyway if not it’s worth the risk of a second hand one to me. |
16th Jan 2025 7:42pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1248 |
I can confirm It was 4 deg last night around midnight, I had been charging via ctek I removed leads and started car to move from garage to front of house. It was very quiet and for the first time when I switched off the engine, I heard and smelled the FBH was operating. Not really noticed it before its so quite. And here in Norfolk not seen any snow this year 2018 SE SDV8 4.4 Byron Blue |
17th Jan 2025 9:00am |
