Home > Technical (L405) > Fuel burning heater help l405
Pablo398
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Hi, I purchased a new fuel burning heater pump a few months back as I had a fault code saying open circuit. Eventually got around to replacing it and all worked great or so I thought. Timer worked, manual heat and key fob. Set it on timer to come on this morning and not working again. I had been for a drive after as I read somewhere that you had to drive between operations. So yesterday I had no fault codes and today I have the following fault codes attached. Is there a common issue for these or have I done something wrong? Thanks for any help..
Post #709323 16th Jan 2025 12:43pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
it wont come on if the fuel level is below a certain amount, for if the battery isnt in tiptop charge. First time FFRR owner
Post #709325 16th Jan 2025 12:53pm
Pablo398
Yeh sorry forgot to mention battery fully charged and full tank.
Post #709327 16th Jan 2025 12:57pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
It also only comes on once between engine starts, so if you had bene playing with it prior to today it would disable it, assuming the engine hadn't been started in the period.
I however doubt that would throw the code you have. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #709330 16th Jan 2025 1:15pm
Pablo398
Yeh started and moved it yesterday after it was working. Also went for a good drive today to check that was not the issue.
Post #709331 16th Jan 2025 1:18pm
Pablo398
Error codes now attached
Post #709337 16th Jan 2025 2:04pm
Pablo398
Post #709338 16th Jan 2025 2:07pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Does it only function below a certain temperature..? I thought it was 4 degrees? Ash
2016 SDV8 AB
Post #709343 16th Jan 2025 2:42pm
Pablo398
Yes it was -1 this morning. And about 2 deg when I went for a drive and tried again. I can clear the fault codes but they keep coming back.
Post #709344 16th Jan 2025 2:48pm
Pablo398
If I need to tackle these 1 by 1 is the auxiliary heater control module the one that the remote operates in the boot or is there another module? And are the flame sensor and overheat sensor just part of the burner or can they be fixed? Just strange I had no fault codes after changing the pump and all working now these faults.
Post #709368 16th Jan 2025 5:46pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
All those faults are in the FBH. It has its own ECU.
I don't know how often they fail, but mine has failed, and blows the fuse, and Christian and Vera from LRTime had theirs fail too.
Post #709373 16th Jan 2025 6:48pm
Pablo398
Thanks so do you think it could just be a fuse? If so do you happen to know which one? Or more than likely a replacement heater.
Post #709374 16th Jan 2025 6:51pm
hmallett
I don't think it's the fuse for you. In my experience that would give you a B129A-88 code (LIN Bus "D" - Bus off).
I wonder whether you could chase down individual faults in the heater, but the spare part prices mean that it's not long before you're at the price of a used FBH. Of course that then probably has no guarantee with it...
Post #709376 16th Jan 2025 7:40pm
Pablo398
Thanks will have a check anyway if not it’s worth the risk of a second hand one to me.
Post #709377 16th Jan 2025 7:42pm
Kot
I can confirm Razz
It was 4 deg last night around midnight, I had been charging via ctek I removed leads and started car to move from garage to front of house. It was very quiet and for the first time when I switched off the engine, I heard and smelled the FBH was operating. Not really noticed it before its so quite. And here in Norfolk not seen any snow this year Razz 2018 SE SDV8 4.4 Byron Blue
Post #709396 17th Jan 2025 9:00am
