Home > Camping, Caravanning and Holidays > Best 13pin caravan plugs. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8641 |
Just for info, the Jaeger one has arrived and as suspected it is almost identical to the Hella one. So that can go in the tub as a spare. There is nothing that can't be fixed with a hammer😜😜
10th Jan 2025 7:30am |
recordman Member Since: 08 May 2013 Location: Kent Posts: 116 |
I've found that the Jaeger ones are of far better quality than the run of the mill cheap stuff found in caravan accessory shops and in Go Outdoors.
10th Jan 2025 12:42pm |
Yep almost exactly the same. Only difference is Hella have added a small pin which locks the outer part into the right place when detached so it’s always correct to insert. The indent is there for it on the jaeger one but the hella actually has it. There is nothing that can't be fixed with a hammer😜😜
11th Jan 2025 10:13am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35403 |
so does every FF have a plug in the boot that you can splice into and run aux rear lights? ... - .- -.
11th Jan 2025 10:17am |
I suppose you could Stan, in theory you could somehow tap into the towing connectors if you knew which wire was which. Basically if you don’t have a tow bar they are on the outside of the rear panel behind the crash bar. 2 grey plugs clipped to the panel, about middle. Should be there ok every car.👍🏻 There is nothing that can't be fixed with a hammer😜😜
11th Jan 2025 9:00pm |
thanks for the insight Mark.. ... - .- -.
11th Jan 2025 9:23pm |
