![]() | Home > Maintenance & Mods (L322) > Aux belts and tensioner replacement |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 215 ![]() ![]() ![]() |
Personally I’d recommend and did on mine genuine LR tensioner, pulleys and water pump. Dayco belt and Denso alternator. |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 281 ![]() ![]() ![]() |
Give GlenRands in Liphook a call - several folk on here use them, including me, and always find them good. They have always supplied/fitted good quality kit for me. TDV8 4.4 2012 |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 153 ![]() ![]() ![]() |
Thanks 2012 4.4 TDV8 Vogue Santorini black ivory leather |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 318 ![]() ![]() ![]() |
I paid £1,175 inc VAT in April 2021 for all the belts, pullies, tensioners and the water pump to be changed, all using OEM (or closest available equivalent) parts at Keith Gott near Alton, Hants. That included 4.5 hours labour and changing the coolant. Here are the parts (note this is for a 4.2SC so probably different for a diesel):
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1434 ![]() ![]() ![]() |
I just paid £1,100 for the same work to be done on my Disco 4 |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2551 ![]() ![]() ![]() |
Some months ago mine's radiator was leaking from the seam under the top hose connection so as well as the radiator, I also replaced all the hoses in the V. Several of the plastic sections crumbled during removal indicating that they wouldn't have lasted much longer even though the engine cover hasn't been fitted since I purchased the vehicle at 19K kms. |
DrF, as your also in the SE would you mind sharing who you used please?
Most of the cost for this job is in the time it takes to remove the fan assembly to gain access so there is a very good argument for replacing everything that can fail. Belts, pulleys, tensioner, alternator, AC compressor, oil pump seals, water pump.
