Home > Technical (L322) > Pressure range |
ThomasKubota Member Since: 22 Oct 2019 Location: Panama Posts: 9 |
Hi everyone, Does anyone know the values for the low pressure and high pressure pump in psi for Range Rover td6 |
8th Jan 2025 3:44am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
8th Jan 2025 8:57am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 |
I'm assuming you mean the fuel pressure as you mention Low and High pressure pump.
8th Jan 2025 10:47am |
Thanks but I didn’t explain clear. I mean fuel pressure . But thanks for your quick answer |
8th Jan 2025 12:37pm |
Hi, yes I mean the fuel pressure. the engine m57. I’m having this code p1180 credibility of the fuel pressure sensor, low pressure side (fuel filter) pre-fuel pressure below the pressure necessary to start. The car crank but star. When I open the switch the pressure next to de filter is 40 psi |
8th Jan 2025 12:39pm |
