Home > Technical (L322) > Pressure range
ThomasKubota
Panama 2006 Range Rover HSE Td6 Adriatic Blue
Pressure range
Hi everyone, Does anyone know the values ​​for the low pressure and high pressure pump in psi for Range Rover td6
Post #708596 8th Jan 2025 3:44am
Post #708605 8th Jan 2025 8:57am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
I'm assuming you mean the fuel pressure as you mention Low and High pressure pump.
From the WSM:
Quote:
The low pressure system pressure is approx. 1.5 bar to 5 bar and return end < 0.6 bar. The pressure in the high
pressure end is 200 bar to 1350 bar.
Post #708618 8th Jan 2025 10:47am
ThomasKubota
nicedayforit wrote:
Thanks but I didn’t explain clear. I mean fuel pressure . But thanks for your quick answer
Post #708635 8th Jan 2025 12:37pm
ThomasKubota
From the WSM:
Hi, yes I mean the fuel pressure. the engine m57. I’m having this code p1180 credibility of the fuel pressure sensor, low pressure side (fuel filter) pre-fuel pressure below the pressure necessary to start. The car crank but star. When I open the switch the pressure next to de filter is 40 psi
Post #708636 8th Jan 2025 12:39pm
